Kubota M9580
/ Kubota M9580 #1
davemorley
Prince Albert
kioti ck2510 hst
We can’t find a serial number on our kubota M9580 and we need a hydraulic pump, Any help, part number etc greatly appreciated
/ Kubota M9580 #3
May I ask what diagnostics were performed to determine hyd pump needing replacing? Have you checked operation of hyd relief valves?
/ Kubota M9580
Not sure what to do. It works if you run it at 2000 rpm, had new oil and new filters
/ Kubota M9580
Hi, it’s a friends tractor he has replaced all the filters and the oil. He said it only shuttles once he get to 2000 rpm…. That’s all I know
/ Kubota M9580 #7
A pump is really expensive. Much more so that a diagnostic call from an actual kubota dealer or mechanic.
Id want to be sure its the pump before I drop more than a grand for a pump and deal with the hassle of changing it
/ Kubota M9580 #8
Id want to be sure its the pump before I drop more than a grand for a pump and deal with the hassle of changing it because if you have other problems in the system, it may be a waste of money and may trash the new pump
2016 PETERBILT 567 TRI AXLE ROLLOFF TRUCK (A65643)
2016 PETERBILT 567...
2013 Keystone Springdale Camper (A62613)
2013 Keystone...
2015 KENWORTH T800 TRI-AXLE (A65643)
2015 KENWORTH T800...
2024 BOBCAT S76 R-SERIES SKID STEER (A65053)
2024 BOBCAT S76...
2016 Ford Transit 350 Wagon Passenger Van (A64556)
2016 Ford Transit...
Lockers (A62613)
Lockers (A62613)
