Kubota M9580
/ Kubota M9580 #1
davemorley
Prince Albert
kioti ck2510 hst
We can’t find a serial number on our kubota M9580 and we need a hydraulic pump, Any help, part number etc greatly appreciated
/ Kubota M9580 #3
May I ask what diagnostics were performed to determine hyd pump needing replacing? Have you checked operation of hyd relief valves?
/ Kubota M9580
Not sure what to do. It works if you run it at 2000 rpm, had new oil and new filters
/ Kubota M9580
Hi, it’s a friends tractor he has replaced all the filters and the oil. He said it only shuttles once he get to 2000 rpm…. That’s all I know
/ Kubota M9580 #7
A pump is really expensive. Much more so that a diagnostic call from an actual kubota dealer or mechanic.
Id want to be sure its the pump before I drop more than a grand for a pump and deal with the hassle of changing it
/ Kubota M9580 #8
Id want to be sure its the pump before I drop more than a grand for a pump and deal with the hassle of changing it because if you have other problems in the system, it may be a waste of money and may trash the new pump
Quick Attach Backing Plate (A65579)
Quick Attach...
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
6' Bush Hog (A62613)
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
