pmsmechanic
Elite Member
- Joined
- Dec 6, 2013
- Messages
- 4,446
- Location
- Southern Alberta, Canada
- Tractor
- 4410 and F-935 John Deere, MF 245
It would be worth it to loosen the belt and see if the pulley is loose.
That is my fear but can't say for sure. As I said earlier, after hearing your video just at the end it sounded like a rod to me. It is very hard to diagnose noise from a video, for me at least.
Boy that video is really a stumper,I don't think there is enough pulley movement there to make that much noise.It's seeming more & more like a rod but the only way to know for sure is to pull the pan and see. Not an easy job as in a lot of cases you have to pull the engine to get the pan off. Depends on how you are set up, shop wise, if you can diy.
Based on everything that's been eliminated at this point, rod knock is about the onlything left, am I correct?
One other thing you could do is compare the frequency of the knock with the RPM of the motor....not quite sure how to do that, but it shouldn't be too hard to get an idea of the ratio, and there is a ton of information to be had there.
luck, rScotty
They are solid lifters, yes. And yes, I ran it without the fan belt on - no difference.
Funny you mention the frequency of the knock. I had the thought too. And actually I do some audio recording/engineering for a hobby, so I have the capabilityI did two takes - one at 1500 RPM and one at 1800 (measured with a tach on the crank pulley). At 1800 rpm, it occurs 15 times per second. At 1500, it's 12.5 times per second. Do the math and that's exactly 1 knock every other revolution. (1800 rpm = 30 rev per second. Divide by 2 =15. Same for 1500.)
Also, when looking at the audio on the spectral frequency graph, the knock occurs every 4th "bang" or "pop" or whatever you want to call the cylinder firing. So the rhythm is "POP, pop, pop, pop, POP, pop, pop, pop"
Not sure what that tells me, but it's food for thought...
To the OP, I am sorry for your troubles. But, tbis is one of the most informative threads I have read in a long time. Kudos to all responding and TBN
If you load the motor and the knock gets lighter, it most likely will be a rod.
I want to think on that... What I'm trying to do is picture how that fits with no overt change in the knock when you disabled each injector.
And so far I can't reconcile the no change and the no injection. I was just so sure that would at least point to the correct cylinder even if it didn't tell us the cause.
A good way to trouble shoot the difficult ones is to divide up the problem. One problem is we don't know which cylinder, the other problem is we don't know why the knock is happening in that cylinder. We ought to be able to at least get it down to the proper cylinder.
Er, I'm assuming that your spectrum analysis is pointing towards one cylinder. Do you agree with that?
Could it even be something crazy? ....like a dangling glow plug end?
I wish I could help more but my reaction is you are delaying the inevitable. Just pull the engine, crack it open and figure it out.
jshwhite
Someone may have already suggested this but have you loosened the inj lines 1 at a time with engine running to determine if knock can be isolated to a certain cylinder? If knock can be isolated to a cylinder I strongly suggest to have that injector or even all injectors pop-off pressure tested.
How many hours does it have on the oil? I think I would change it and send a sample to a lab to have it analyzed. If it is a main or rod bearing that'll tell you.
