Buying Advice kubota l4200
/ kubota l4200 #4
Nothing out of the ordinary...
I guess it would depend on the hours on the tractor & what type of work it has been doing...
The hydraulic clutches are usually good for a Long time, the dry main clutch is generally Never used... but if it has been used it & the pilot bearing can show problems before 1000 hours.
The pto has a wet clutch pack & is generally not a problem it has a brake system that can get excessive wear if heavy pto loads are not idled down before disengaging the pto...
It is a well engineered tractor with no real weak points...KennyV
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
Denyo DCA-600SPK 500kW Sound-Attenuated Diesel Generator (A63689)
Denyo DCA-600SPK...
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
Ford Pickup Truck Bed (A61573)
Ford Pickup Truck...
2014 Honda Accord Sedan (A61574)
2014 Honda Accord...
