Buying Advice kubota l4200
/ kubota l4200 #4
Nothing out of the ordinary...
I guess it would depend on the hours on the tractor & what type of work it has been doing...
The hydraulic clutches are usually good for a Long time, the dry main clutch is generally Never used... but if it has been used it & the pilot bearing can show problems before 1000 hours.
The pto has a wet clutch pack & is generally not a problem it has a brake system that can get excessive wear if heavy pto loads are not idled down before disengaging the pto...
It is a well engineered tractor with no real weak points...KennyV
LOADER MOUNT HAY SPEAR (A63291)
LOADER MOUNT HAY...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2023 John Deere 333G Track Loader (A63111)
2023 John Deere...
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
2012 CATERPILLAR 259B3 SKID STEER (A64279)
2012 CATERPILLAR...
