Buying Advice kubota l4200
/ kubota l4200 #4
Nothing out of the ordinary...
I guess it would depend on the hours on the tractor & what type of work it has been doing...
The hydraulic clutches are usually good for a Long time, the dry main clutch is generally Never used... but if it has been used it & the pilot bearing can show problems before 1000 hours.
The pto has a wet clutch pack & is generally not a problem it has a brake system that can get excessive wear if heavy pto loads are not idled down before disengaging the pto...
It is a well engineered tractor with no real weak points...KennyV
207283 (A52708)
207283 (A52708)
12in. Tooth Excavator Bucket (A64194)
12in. Tooth...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2022 EZ-GO ELITE...
CASE INTERNATIONAL 6088 RWD COMBINE (A63291)
CASE INTERNATIONAL...
Rhino 12ft Blade (A63688)
Rhino 12ft Blade...
