Buying Advice kubota l4200
/ kubota l4200 #4
Nothing out of the ordinary...
I guess it would depend on the hours on the tractor & what type of work it has been doing...
The hydraulic clutches are usually good for a Long time, the dry main clutch is generally Never used... but if it has been used it & the pilot bearing can show problems before 1000 hours.
The pto has a wet clutch pack & is generally not a problem it has a brake system that can get excessive wear if heavy pto loads are not idled down before disengaging the pto...
It is a well engineered tractor with no real weak points...KennyV
2019 Peterbilt 567 Quint Dump (A62613)
2019 Peterbilt 567...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
JRB 52" HANG-ON WHEEL LOADER FORKS (A63276)
JRB 52" HANG-ON...
2010 Kenworth T3 Class 7 Flatbed, 4x2, w Tuck-Under Liftgate (A63689)
2010 Kenworth T3...
HOLLAND 4R FINGER TYPE SETTER (A63291)
HOLLAND 4R FINGER...
