Comparison Kubota L3301 vs L3800
/ Kubota L3301 vs L3800 #1
lowcomotion
morris, ct
Kubota B2620, JD 6400
Hi Everyone. Finally became a member of your great commuity, looking forward to contributing what I can. I have a questions regarding the differences between the L3301 and L3800.
The L3800hst has a list of $19,300 vs. the L3301hst list of$19,600. I was wondering what the differences were between these two machines that would warrant more cost for less HP. I've looked around a little but haven't found anything that stands out. Any ideas would be appreciated. Thanks!
/ Kubota L3301 vs L3800 #2
Well the L3301 has the Tier 4 Final emission standard equipment on board. The L3800 is now an obsolete model that met Tier 4 Interim emission standards which are not near as stringent as Tier 4 Final. As you noted the L3800 has more horsepower. The L3800 fall in the group that may or may not have a jerky 3pt rear hitch, Some people say that theirs in not jerky when being raised with a load slowly. All I have seen are, but then I haven't looked at every one they made. :)
The new L3301 and the L3901 models do not seem to have this problem. There have been 0 reports here, so it seems at long last this problem has been put to bed by Kubota. I traded off my L3400 (predecessor to the L3800) as it had a very jerky 3pt, but the L3901 which is the successor to the L3800 seems to be free of this. There are a few minor cosmetic changes, as there always are with each model change, but nothing major.
/ Kubota L3301 vs L3800 #3
When I bought my L4600 the dealer said it was being replaced by L4701 with tier 4 engine he said it would add 3 to 4 grand to price to me that's a lot would cause someone to step down to lesser hp to be able to afford it
/ Kubota L3301 vs L3800 #4
What exactly does tier IV mean for these tractors? DEF tank, EGR, or what?
/ Kubota L3301 vs L3800 #5
I think it is common rail injection, and a Diesel Particulate Filter. I don't believe there is any DEF on these.
/ Kubota L3301 vs L3800 #6
Tier 4 eng is a electronic computerized the old mechanical fuel injection pump is replaced by computer controlled injectors it has a lot of different sensors to update computer and it takes a scan tool or a lap top with special software to communicate with it. not all use DEF also know as diesel exhaust fluid. one of problems that you would have is not being able to communicate with it one sensor can go out and no run and unless you can talk to it your guessing at some costly parts
/ Kubota L3301 vs L3800 #7
I don't have allot to contribute here but I saw the thread title and figured I would check things out. I very recently purchased the L3301 with hydrostatic drive. It's the first tractor I've ever owned, but I grew up running various machines for friends and family members. I have been very impressed with this machine. The only concerns I might have are being discussed in another thread right now titled tier 4 info. I'm not real good on these forums, I don't know how to link to the thread. You could probably look at my recent posts? Or if someone knows how to link it?
Anyhow, it is my uneducated understanding that the 2 models are pretty closely related other than the emissions as stated. Mine has the dpf and related electronics. The longetivity of this is discussed in that other thread. Mine doesn't have the jerky 3 point hitch either. If either of them meet your needs, I doubt you could go wrong with either one, other than this possible 3 point issue
/ Kubota L3301 vs L3800 #8
The L3200 (32HP) and L3800 (38HP) were recently replaced by the L3301 (33HP with emissions claptrap) and L3901 (39HP with emissions claptrap). Last year for the 3200/3800 was 2013, so not very long ago.
Really, the even comparison would be between the L3200 and L3301, or L3800 and L3901. What you'll find in each case is a price increase commensurate with some very minor changes and all the emissions crap. That costs $$.
If you can find a 3200 or 3800, you will save money and hassles. They are getting scarce though. A lot of people jumped on them knowing the new models would cost more and have complicated emissions systems.
/ Kubota L3301 vs L3800 #9
fyi. these are tier 4a, not tier 4 final. In a few years when tier 4b\final rolls in there will be more changes, DEF I think. This is happening with 75+ HP next year.
/ Kubota L3301 vs L3800 #10
I will have to look back again, but I believe the literature on mine states tier 4 final. And no Def. But I wouldn't be surprised on the bigger machines. They found out quickly on trucks that they worked much better with Def
/ Kubota L3301 vs L3800 #11
Unless you will be using a box blade or other grading device as a great portion of your tractor use, jump on that l3800 before it's gone.
For me it's a simple choice, more HP, less computer junk to fail, and a cheaper price tag.
/ Kubota L3301 vs L3800 #12
Why does the box blade make the difference? You mean because of the jumpy hitch?
/ Kubota L3301 vs L3800 #13
That is surely what he meant, but it hasn't been an issue for me so far and I do quite a bit of box blade work. It could be an issue if you need to slowly/gradually lift a box. I tend to feather off my grading work as material runs out or with adjustments to the top link, so I almost never need to raise the box slowly.
/ Kubota L3301 vs L3800 #14
I need to research this some more. Since this is my first tractor, I have no box blade experience. I just bought a small piece of property with about a 1000' road that has some rutted, low spots. As dry as it is, its hard as nails right now. I don't have much money so I can't really afford to bring in the road base material that I would prefer to use to fill this in and grade it. So I've been told that a box blade is my best bet for trying to smooth this out. The FEL kind of tries to skim the tops of the ruts, but just bounces off of the deeper stuff.
/ Kubota L3301 vs L3800 #15
A box blade will be helpful for your road maintenance. Or a grader scraper. Even a simple back blade will work. Best option would be to have all three, but obviously that's a lot of $$.
I certainly didn't mean to imply that the potentially "jerky" 3pt would prevent you from effectively using that type of stuff. You should be able to make it work just fine, and the addition of a hydraulic top-link would be a great way to solve any problem you run into with feathering the lift.
/ Kubota L3301 vs L3800 #16
I will look into all of that, thanks! Honestly, I'll have to google the terms to know what they are, haha. I'm VERY new to this stuff. I'm a city boy. I like to tinker and build stuff. I think it would be neat to create a 3 point hitch and hydraulically driven pto hookup for the front quick attach and build these implements to go on the front. I say "create", but I know alot of this has probably been done by many before me. My thoughts are to basically build a pivoting box blade to go in place of the FEL. Then you have tilt for different drag and push angles, and left to right pivot adjustment to move material away from walls/into ruts, whatever. And sides to trap excess material.
And the pto and 3 point attachment points will be for future hookup of a front mounted bush hog, rotary tiller, etc. Since I'm new to this, I could be way off track, but it seems to me that you have way more control, and definately more comfort by putting your implements up front, rather than behind you. Plus with the FEL arms, you've already got alot more adjustability and range of motion to start with than the 3 point arms on the back
/ Kubota L3301 vs L3800 #17
The problem with ground engaging implements is that most will bend your front loader arms under extreme use, whereas the rear 3-pt setup is a lot less fragile and is setup for ground engaging work. It has short heavy gauge links that are made to be in tension when pulling a ground engaging implement. If you hit an obstacle you'll either kill the engine, hit a relief on an HST, or just spin the tires. In contrast, the front loader is a lot more complicated and it's engineered to lift, no to push. Yes, you can do quite a bit with the front loader but those long skinny-gauge arms, all the links and pins, and the cylinders make it a whole lot less robust than the 3-pt, and plenty of people find this out the hard way. There are dozens/hundreds of threads on here from people who have messed up their front loader doing something they shouldn't have.
If I do any pushing with my front loader, it's generally using the hydraulics only, since they should go into relief before any structure starts to bend or break. I do limited ground engaging work only when in soft soil.
Really, look at the difference between a tractor's front loader arms and the arms on a bulldozer to get an idea of why each has a specific design.
/ Kubota L3301 vs L3800 #18
You've crushed my dreams...
Just kidding. That is a very good point. Hopefully at some point I can afford the top filler material, and maybe even a pro to come in and level it. Then my inventions will only be needed to gently maintain, not actually dig in and sculpt.
/ Kubota L3301 vs L3800 #19
You can do some very aggressive shaping with a box blade, especially with rippers down. I wouldn't rule it out. When we were building our new house, I had to re-do the driveway every couple weeks until it got established and setup in drier weather. Before and after any cement truck deliveries, I would knock down high spots and fill in ruts. The more uniform the material, the easier it is, as the box will take material off high spots and drop it into low spots. If the material is really mixed up, it gets more challenging.
/ Kubota L3301 vs L3800 #20
I probably use my box blade with my L3800 more than any other implement and nearly always have it on as my first choice for rear ballast anyway (it weighs 550 lbs). I maintain our neighborhood's gravel road. If I purposely try to very slowly raise the 3PT, I do get some jerk especially when it is just warming up, but it is certainly very manageable and I have been able to easily shape and sculpt property as well as the road. Most of the time on the road, I simply drop the box with the rippers in the highest setting, but just slightly below the blade and keep it level. It easily breaks up the hard pack and fills and I feather as I go. I drag it so the lower parts fill in naturally with the shape of the blade being level. 2 passes on our road and all is well again. It is really a narrow lane so 2 passes on each side of the crown is all it every takes. This tractor will easily pull my 6ft BB full up the hills in 4X4 M range.
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2001 Toro Reelmaster 5400-D 100in Fairway Reel Mower (A59228)
2001 Toro...
John Deere 6120M (A57148)
John Deere 6120M...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
1608 (A57192)
1608 (A57192)
