Kubota L3301 issues
   / Kubota L3301 issues #32
Unless things have changed, on Kubota L series tractors R1 tires come on 2 piece wheels. An outer rim and an inner disc. The outer rim can be mounted with a 2" offset in or out on the disc. Also, the disc can be mounted to the axle either dish "in" or "out". The R4 tire is mounted on a rigid no adjustable rim. Otherwise, if you want to be able to widen the rear width, then you will need to go with "R1's"
Look at my first picture, just above your post. As I said then, my wheels are at their widest setting.
   / Kubota L3301 issues #33
Well imo you can do it will it be hard on the tractor and slow going, yes I cleared a couple acres on a hill with my old L2850 the three point BH made it work for me plus added 1500 lbs of weight to the tractor. When everything was to a point I was happy with i definitely felt a sense of accomplishment. Unfortunately I ended up rebuilding the front axle on it, new seals, bearings, and a bevel gear. I waited five years to finish the rest of the acres after I got my skid steer which ended up doing the same amount of work in a fraction of the time and no breakdowns. Good luck.
   / Kubota L3301 issues #34
Hell sell the Kubota and buy a CAT D9. Go big or go home.
It is amazing how every time someone asks for help the solution is "you need a bigger tractor." Maybe that is the biggest tractor he can afford. Sure you can do it faster with a larger tractor but that does not mean the work can not be done with what he has to work with.
There is not a lot of information given as to what kind of work needs to be done but I bet a lot could be done with the L3301. Large stumps or mountains of dirt may require some bigger equipment at some point but a lot of hard work and time the L3301 will clean up a lot of a mess. After all isn't the reason for a tractor is to work it?
If I only had a bigger tractor I could pave farm the world.
The OP said clear fence lines. If he meant fence lines consisting of his wife's rose bushes then he's ready to go.
I've cleared some fence lines last fall using a 25 ton excavator. My 5 ton CUT lifts 4,000lbs and can barely move the larger root ball stumps. Good luck with a 1,500 lb tractor.
FYI the excavator struggled on pushing out some of the trees. Let's get realistic with expectations here.
   / Kubota L3301 issues #35
Where did you read that?
I am leaving the bigger trees where they are, but its mostly brush with invasives, as we have gotten hit by several fires that resulted in good start for clearing.
   / Kubota L3301 issues #38
If you are talking about mowing brush & stuff up to an inch, maybe 2" in diameter on up to 5 or 10 acres, an economy L will be slow but very acceptable. It would be a great machine for annual mowing of 5-10 acres. A hoe on an economy L will dig out some smaller trees. But if you are talking bigger trees or lots of trees, you probably want a better tool for the job.
How big is the brush or trees you are trying to deal with? How many trees? How fast do you need to do the work? In some cases you xan just go slow with a small machine & do the job fine. When dealing with heavier stuff you need more machine.
A tractor is not a digging machine, not even one 10x the size of an L. The impliment is called a loader, not a digger for a reason. A skid steer isn't even really a digging machine, although they are a lot better than a tractor. They do a great job grading. If you want to dig you need a backhoe or an excavator.
I rented the heavy stuff to originally clear my land, but it got to be costly as you can imagine. So got a JD 790 with loader and backhoe and been using that for many years, but the other lots have been sitting there growing invasive trees and brush, but the fires did knock down some as it nearly burned my house. So got the L3301 and getting it set up to clear the other lots as they are a bit down the road, and do fire breaks around the house.
2016 Chevrolet Traverse SUV (A59231)
2016 Chevrolet...
CAT 930M (A58214)
CAT 930M (A58214)
2011 Chevrolet Impala Sedan (A59231)
2011 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
