Kubota L305D
/ Kubota L305D #1
loboracer
massey ferguson 1720 tlb
I just bought this thing and after about 5 min of brush hogging I have a red idiot light on. I am not sure what it is. It is on the left side of the rpm gauge. Oil light maybe? Low oil pressure, temp or level? Oil level was fine. Any help would be appreciated. I cant find an online shop pdf manual for it.
/ Kubota L305D #2
Based on what your saying; should be item #29; engine temp. Check coolant level, condition, and radiator and radiator screen. From there, if those all good, could be thermostat, or water pump. My assumption is, radiator is nasty dirty
/ Kubota L305D #3
...and most likely loaded with brush hog chaff as well You do have to perform maintainance on any unit especially when running a shredder and if you kept on running it with the light on chances are you'll be into a lot more serious issues than a cruddy or blocked radiator.
Far as online manuals go, there are a number of sites like Online manuals .net that offer them.
Finally, never buy ANY tractor without at least the owners manual included.
/ Kubota L305D #4
How about a little more info on your new-to-you machine? Hours, year? These were last made in 1985 says TractorData. No matter in that regard as I have a B 2150 made in the 1980's in the best shape of any similar one I've ever seen.
Note to admin of TBN: showing laboracer as "New member" and date of joining as Sept. 5, 2019 might be a tad off...?
/ Kubota L305D #5
Check kubota books and see if the manual is on there it's free.
1993 Ford LS9000 Tri-Axle Dump Truck (A61573)
1993 Ford LS9000...
213098 (A64276)
213098 (A64276)
2011 Dodge Ram 1500 Crew Cab Pickup Truck (A61573)
2011 Dodge Ram...
(9) WOODEN 4' MILITARY CARGO / AMMO BOXES (A64281)
(9) WOODEN 4'...
John Deere 1025R (A62177)
John Deere 1025R...
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
