Kubota L2850
/ Kubota L2850 #1
ags1517
Does any one know about gearbox, rear axle and hydraulics on this tractor. I have no manual. Can find one sight glass for oil level on LHS of gearbox, do all 3 use one common supply of oil? as there are 2 top up points one on top of the gearbox, and one at the top of the 3 point linkage both large red plastic caps. Also what oil should be in it.
Thank You
/ Kubota L2850 #2
I don't know for certain on that model, you might just call your local Kubota dealer and ask them. They can also order you an owners manual for future reference if you like.
/ Kubota L2850 #3
Hi,
Yes all three sections use the same oil and you can fill from the red cap on the gearbox side since much faster.
On the LHS glass shows low & high level and try to keep it in the middle, going for the high.
I use shell Donax TD 10w30.
hope this helps
regards /forums/images/graemlins/ooo.gif
/ Kubota L2850
Thanks for your help, I am trying to get a manual at the moment but your advice will let me start the easy jobs. Thanks again. /forums/images/graemlins/smile.gif
6ft. 3pt. Blade (A65640)
6ft. 3pt. Blade...
Heaven Hill Burbon Barrel (A65583)
Heaven Hill Burbon...
2017 HAMM H12i PADFOOT ROLLER (A65053)
2017 HAMM H12i...
2022 EZ-GO ELITE...
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
2000 Volvo Semi Truck (A66285)
2000 Volvo Semi...
