Kubota ign. Keys
/ Kubota ign. Keys #1
sscrob
Crocker MO
Kubota L3240
How many different keys does kubota use on their tractors. My dad has a L3010 HST and I just got a L3240 HST. I was surprised when the keys were the same. Also I'm still looking for the wiring order for my hand cruise lever, the previous owner caught the wires on something and pulled the terminals out of the plastic connector. It's a 4 wire connector on the bottom of the cruise lever on my L3240 HST. Thanks Rob
/ Kubota ign. Keys #2
Most equipment uses a generic key. The key for my Massey 1020 is the same key for a Ford 8n. Even heavy equipment utilizes a generic key. They probably have a different key for each series of machine.
/ Kubota ign. Keys #3
Not many variations the 5030 and 5740 are the same.
/ Kubota ign. Keys #4
agreed, if you have a Kubota tractor key, it'll likely fit a very large number of models.
/ Kubota ign. Keys
A picture of the tractor or the connector I need to wire?
/ Kubota ign. Keys #7
I have read other posts and threads here on TBN that relate to various brands of tractors' keys fitting the ignitions of other brands and models.
/ Kubota ign. Keys
I knew that CAT stuff all used the same key, but they don't look like a normal key. Might have to add a secret switch for peace of mind.
/ Kubota ign. Keys
I haven't had a need for the cruise control yet but the error message is driving me nuts!!
/ Kubota ign. Keys #11
My dealer handed me two keys, and told me they would operate every tractor on the lot. One key for open stations, and the other key for the cab models. (Kubota)
/ Kubota ign. Keys #12
My B7800 and L4300 are different.
L4300 and MX5100 are the same.
Not sure but big M8950 and L4300 and MX5100 look the same.
/ Kubota ign. Keys #13
You need a wiring diagram and it should be contained within the WSM
(Work Shop Manual ) I kicked and moaned and groaned as well not wanting
to spend the money for one but once I did it I realized I was a fool for not
obtaining it sooner.
I can be of help in so much that I think I know where you can buy the
WSM for your tractor for a VERY fair price and I do believe if you tell
the man you found him via me ("Artisan" on the TBN Forum) I do believe
you will get free shipping as well, PLUS the price will probably be better
than anywhere else. Shoot and EMAIL to Tracy at Lashey Tractor Sales.
/ Kubota ign. Keys #14
PS, I have the WSM for my BX25 and it has a Wiring Diagram
inside it, a fold out centerfold kinda deal...So a WSm for your
tractor "Should" have it as well... You will thank yourself for
years to come, the info contained within a WSM is a
pleathora of info you NEED. Get a thre ring binder ready
for when it arrives...a pretty big one. My WSM is almost
1.5' thick! The user manual is in addition to that!
/ Kubota ign. Keys
Thanks, I'll check into that, I was going to order one off of eBay but I'd rather spend the money with a member here if the price is comparable.
/ Kubota ign. Keys #16
Worse than that, larger aircraft don't use any keys....
/ Kubota ign. Keys #17
I'm working all weekend but I can unplug mine and take a picture of the connector on Monday. One thing you'll want to look for is the little piece of plastic that locks each pin in place. If it got broken you may need to get tricky and epoxy the pins back in place or see if you can but just the plastic shell.
/ Kubota ign. Keys #18
Key's i have three different Kubota key's , 1) B series , 2) L series ,and 3) M series . Not sure about the BX.
/ Kubota ign. Keys
That would be great. I'll be sure that the terminals are secure. Thanks, Rob
/ Kubota ign. Keys #20
I have two different Kubota keys. One (smaller) works on the BX, F2680, F3080 and RTV1140.
The other key (larger) works on the B2320 and B2620 and B3200 and can't remember for sure but believe it also worked on the L3240.
211297 (A62131)
211297 (A62131)
1994 JET 96" X 40' ALUMINUM HOPPER BOTTOM TRL (A63290)
1994 JET 96" X 40'...
(2) FRONT MOUNT TANKS & BOOM OFF JOHN DEERE 4020 (A63745)
(2) FRONT MOUNT...
COLE MULE TYPE PLANTER (A63745)
COLE MULE TYPE...
2013 John Deere 8360RT Track Tractor (A63109)
2013 John Deere...
1999 JOHN DEERE 344H WHEEL LOADER (A63276)
1999 JOHN DEERE...
