Kubota hydraulic problem
/ Kubota hydraulic problem #1
Tedmx5000
Kubota mx5000
I own a kubota mx5000 tractor. While changing a hydraulic hose I had to remove the valve body to get access to the hose fitting. While off the valve body slid down and landed on the joystick. Now the bucket won’t go up. Took covers off of valve unit and spool will not come out. Took the valve apart and found lots of corrosion around detention end. Cleaned up and put back together. By the way the spool slid perfectly when the valve was apart and looks brand new. Spool still won’t come out.
Help please
/ Kubota hydraulic problem #2
Help please
It sounds to me as though you may have bent something in the linkage..?
2012 Caterpillar 302.5C Mini Excavator (A61572)
2012 Caterpillar...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2022 Peterbilt 567...
Unused 10-16.5NHS Skid Steer Wheels and Tires (A61572)
Unused 10-16.5NHS...
Bobcat S66 Skid Steer (A63688)
Bobcat S66 Skid...
UNUSED IRANCH IRGC40 HIGH END MINI GOLF CART (A64281)
UNUSED IRANCH...
2001 Freightliner MB55 Bus (A61573)
2001 Freightliner...
