Kubota hydraulic problem
/ Kubota hydraulic problem #1
Tedmx5000
Kubota mx5000
I own a kubota mx5000 tractor. While changing a hydraulic hose I had to remove the valve body to get access to the hose fitting. While off the valve body slid down and landed on the joystick. Now the bucket won’t go up. Took covers off of valve unit and spool will not come out. Took the valve apart and found lots of corrosion around detention end. Cleaned up and put back together. By the way the spool slid perfectly when the valve was apart and looks brand new. Spool still won’t come out.
Help please
/ Kubota hydraulic problem #2
Help please
It sounds to me as though you may have bent something in the linkage..?
GENIE AWP-36S MAN LIFT (A60736)
GENIE AWP-36S MAN...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
Toro Sand Pro (A56859)
1999 Sterling L9513 Tri-Axle Roll Off Truck (A61568)
1999 Sterling...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
