Kubota Gross HP vs Net
   / Kubota Gross HP vs Net
With as many different brands as there are for CUTs under 45hp I figured most of the ratings where for competition between brands.. Yes it is amazing what weight will do in the right places on a tractor. The 3240 I have pulls a disc way better than the 7 HP more older tractor I was use to.. 4wd and about 1200lbs makes WAY more difference than 2wd and lesser weight..... I do like the draw bar HP rating- but as Phil stated most CUT use PTO HP more than draw bar power...Yes I am getting a tiller and may retire that old 7ft disc!
AndyG
   / Kubota Gross HP vs Net #13
  • ENGINEL4240SPECS.pdf
Phil- where did you get that? I have the babyG L3240... In my hot rodding days HP was speed and Torq was calc in how many sets of rear tires you went thru :laughing:
AndyG
   / Kubota Gross HP vs Net #15
where did you get that? I have the babyG L3240:
AndyG
Here is the curve for the L3240. You may be able to find online, but we use alot of Kubota, Deere, Cummins, and Cat engines here where I work, so I had the referance data on hand. Philip.
  • ENGINEL3240SPECS.pdf
   / Kubota Gross HP vs Net #17
I'm kind of surprised that they don't give torque numbers.
Yea, all the small lawnmower type engines are rated in torque instead of HP now. I heard that was mandated due to mfgs fluffing their numbers. When I was a kid, a 22" cut 3.5 hp mower would really lay down the grass. The last push mower I bought claimed 5hp I think and it was down right disappointing.
Ian
   / Kubota Gross HP vs Net #18
your gross engine hp is based on 2500rpms.the pto hp is usually 5 to 10hp under the engine hp.
   / Kubota Gross HP vs Net #19
This is an extremely vauge statement and would not consider it standard for any comparisons. Are you talking about one specific model or for every tractor in general? Philip.
   / Kubota Gross HP vs Net #20
Gross engine hp is basically meaningless. As a rule pto hp is about 15% less than gross power and draw bar hp is 15% less than pto whether you are talking 20 hp or 200hp.
TANK MANIFOLD (A58214)
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
light tower (A56857)
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
