Kubota Gross HP vs Net
   / Kubota Gross HP vs Net #1
Agrantina
Platinum Member
West Tennessee
Kubota L3240 GST
Just crossed my mind when looking at some other brands and their HP ratings. I noticed that Kubota has a Gross HP rating and then gives a Net HP rating. John Deere just gives a Gross HP rating only, while New Holland says engine power? Whats the difference in gross and net? HP rating off the motor vs thru the tranny rating?
What they trying to hide?
AndyG
   / Kubota Gross HP vs Net #2
See attached Kubota engine spec sheet, look at definitions at bottom, see if this helps. In the industrial engine world, intermittent power is defined as the max power the manufacture will allow you to use for one full hour without interuption in reduced power, followed by one hour with the engine operating at or below the continuous hp, with engine hours not exceeding 3000 hours per year. Continuous power is defined as the max power the manufacture will allow you to use for a contstant load application with a 100% duty cycle, with engine hours exceeding 4000 hour per year. This has to do with warrantly and life expectancy of the engine. Gross is without fan, air cleaner, and muffler. Net is with fan, air cleaner, and muffler. In the case of your L3240, how I interperate this, Kubota is saying your L3240 engine makes a gross intermittent hp of 34, has a net intermittent hp of 32 which can be used for 1 full hour followed by 1 hour at or below the continuous curve not to exceed 3000 hours per year, and has a continuous hp of 27 that can be used 100% of the time without interruption for over 4000 hours per year. In the industrial / stationary engine world (where I work) this makes more sense where we rack up thousands of hours per year. But, we still need to know how to compare gross, net, and continuous between manufacturers, as you have noticed. Philip.
  • ENGINEOVERVIEW01.pdf
  • engineratings01.pdf
   / Kubota Gross HP vs Net #3
Parasitic losses. IIRC, Net HP = Gross HP - all of the losses up to the flywheel (alternator, hydraulic pumps, water pump, muffler after the manifold, polution control, etc). I don't think it deducts driveline losses. I think that would be Drawbar HP.
I see Philip8N beat me to it with much better info. Dang.
   / Kubota Gross HP vs Net #4
My father always taught us PTO horsepower is important that's what you really have for the work at hand, if you notice most equipment gives PTO horsepower recommendations not engine horsepower take care
   / Kubota Gross HP vs Net #5
+1.
Most older tractors didn't even bother to give an engine HP. They only gave PTO HP and drawbar HP, because those are ther two that actually matter.
Thanks Phil--- It is clear as mud now..:D Well not really I understand the diff now, SO the next question is why doesn't Kubota give a draw bar HP? It looks like the draw bar rating would be a few less than net HP... It just seems funny to me with ALL the different manufactures how each one posts a different spec on their machines HP rating. Their are ALOT of CUTs that have 2-4 HP difference...
Can one really tell 2 HP difference? I still say WEIGHT has alot to do with HP to the ground!!
AndyG
   / Kubota Gross HP vs Net #7
I think because no one is doing field tillage work with L3240's, L3940's, L5740's. I have only seen drawbar horsepower listed on older ag farm tractors, where weight has a great effect. Drawbar hp is the horsepower avaiable to pull, taking engine power, weight, tire slippage, etc, and putting that into a horsepower available to pull. Search Nebraska tractor testing for more info. What is probably most important as a fair comparison, as stated above, is pto hp. Philip.
   / Kubota Gross HP vs Net #8
... It just seems funny to me with ALL the different manufactures how each one posts a different spec on their machines HP rating. .................I still say WEIGHT has a lot to do with HP to the ground!!....
In the old days, tractors were rated as 1-bottom or 2-bottom or 3-bottom etc. reflecting how many plows they would pull. That gave way to rating them by pto horsepower (power available to do useful work). But higher power sounds better to customers so the marketing people started counting every last drop of power made - including air pumped by the fan, noise made, heat generated, etc. in the effort to out-do the competition. There were only loose standards by gentlemen's agreement. As more off-shore manufacturers entered the game things got worse - but eventually the industry sorta standardized on the "net hp" rating. Thing is, even that is not a rigidly enforced standard so precise comparison is still approximate. And you are spot on - without the weight to couple it to the ground, potential power's value is hard to measure.
With all that said, I still stand by by old TBN signature "Power is Good - So is Weight" ;)
   / Kubota Gross HP vs Net #9
AndyG
Wow! Isn't it interesting statement about our society when we automatically assume that advertisers are trying to hide something rather than give us more information.
I'm reminded when one of my buddys came and asked how in the world could a Sears air compressor be rated at more HP than the wall socket could put out. The answer is that it actually can, but sure enough it's a trick.
In the case of tractor motors, GROSS HP is supposed to be what the bare engine puts out even though nobody uses any engine that way. And NET HP is the usable HP that actually travels though the transmission and does work on the ground while also turning things like the fan, alternator, and hydraulic pump. So you brag on Gross and figure with Net. The difference between the two keeps engineers employed.
Frankly, HP isn't what tractors are about anyway unless you care how fast you can go at full load. With enough gearing, even tiny tractors have more than plenty of HP. The limiting things are more likely to be weight, stability, and traction.
Good Luck, rScotty
   / Kubota Gross HP vs Net #10
I'm kind of surprised that they don't give torque numbers.
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2016 Bobcat E85 Midi Excavator (A59228)
2016 Bobcat E85...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2020 Nissan Rogue SUV (A59231)
2020 Nissan Rogue...
