Pat's Easy Change Kubota BX25
/ Kubota BX25 #1
Highwayman14
Society Hill
Kubota BX25D-1
Before I order a Pat's easy change for by BX25 I was wondering if anybody else had used one on that model of Kubota and if so which category did you order. Thanks in advance!
/ Kubota BX25 #2
I too am interested in hearing from others what their experiences are with quick hitches. I have a New Holland tc30 and have always been curious how well it works.
/ Kubota BX25 #3
I have had a set of cat 1's on my 35hp tractor for about a year. I am thrilled with them and wonder why I didn't do it sooner. I've gone from fighting with 3pt implements to watching them snap right on. I also have a hydraulic top link so between that and the Pat's installing and removing implements is fast and easy.
/ Kubota BX25 #5
Just purchased set #2 for the 5500. IMHO the best addition to my tractors. If a MFG wanted to blow out the competition - they would offer a PATS style end instead of the ball as a option. Most category 3 is a quick hitch type coupler.
I have thought about cutting the balls off my lift arms and welding the PATS on (availablr thru Greenwell Mfg).
My brother has a QH and had to modify some of his equipment and all of the toplink to work. With PATS, any 3PT attachment will work w/o major modification.
I did add a bent washer to the bottom of the supplied washers to keep them straight on the pin. Also made extras using 2 bent washers welded to a 1" flat washer for the hitchpin.
Also, the pins on my boxblade were sloppy and I replaced with a longer pin and welded a flat bar back to the frame to create a clevis hookup. Back blading will wear out the pins on BB quick and a clevis hookup works!
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
TUGGER TRAILER (A55745)
TUGGER TRAILER...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
207283 (A52708)
207283 (A52708)
