Kubota Boom cylinder leaking
   / Kubota Boom cylinder leaking #1
racer86y
2010 Kubota L2800
2010 Kubota L2800 started spraying this tiny leak.Where is the best place to buy only what i need?I assume it needs a seal pack of some kind,but not 140 bucks for 6 or 7 rubber o rings.Any help would be appreciated
A little rich for my blood.However i did find all 4 cylinders for $50 and $15 for tools to do it with.I just hope nothing is broke inside.Kit would not work after all that
   / Kubota Boom cylinder leaking #4
When and if I have a leaking cylinder, I take it to a hydraulic shop and have them rebuild it. Some are a bugger to get apart and some require special spanner wrenches as well. Easier to have a shop that specializes in rebuilding - repairing cylinders do it. Much less hassle, least for me.
Building a house right now and money is tight or i would let a shop do it as well.
   / Kubota Boom cylinder leaking #6
I believe you will find that you need a complete rebuild kit if you can get it apart, that is.
I watched a couple U Tube videos and besides o rings,there is not much else,but if there is then it gets expensive it appears
Getting it apart was easy but the o ring kit was wrong one.I can't read serial# so i don't know which one to order now
2014 10ft T/A Dump Trailer (A51692)
2014 10ft T/A Dump...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A54607)
2007 POWERSCREEN...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A53473)
2020 New Holland...
2017 Mitsubishi Fuso 16FT Box Truck (A51692)
2017 Mitsubishi...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A53473)
Heavy-Duty...
