Kubota Boom cylinder leaking
/ Kubota Boom cylinder leaking #1
racer86y
2010 Kubota L2800
2010 Kubota L2800 started spraying this tiny leak.Where is the best place to buy only what i need?I assume it needs a seal pack of some kind,but not 140 bucks for 6 or 7 rubber o rings.Any help would be appreciated
A little rich for my blood.However i did find all 4 cylinders for $50 and $15 for tools to do it with.I just hope nothing is broke inside.Kit would not work after all that
/ Kubota Boom cylinder leaking #4
When and if I have a leaking cylinder, I take it to a hydraulic shop and have them rebuild it. Some are a bugger to get apart and some require special spanner wrenches as well. Easier to have a shop that specializes in rebuilding - repairing cylinders do it. Much less hassle, least for me.
Building a house right now and money is tight or i would let a shop do it as well.
I believe you will find that you need a complete rebuild kit if you can get it apart, that is.
I watched a couple U Tube videos and besides o rings,there is not much else,but if there is then it gets expensive it appears
Getting it apart was easy but the o ring kit was wrong one.I can't read serial# so i don't know which one to order now
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
2014 FORD F-150 (A60736)
2014 FORD F-150...
500BBL WHEELED...
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
2011 JOHN DEERE 75D EXCAVATOR (A62129)
2011 JOHN DEERE...
