Kubota Boom cylinder leaking
/ Kubota Boom cylinder leaking #1
racer86y
2010 Kubota L2800
2010 Kubota L2800 started spraying this tiny leak.Where is the best place to buy only what i need?I assume it needs a seal pack of some kind,but not 140 bucks for 6 or 7 rubber o rings.Any help would be appreciated
A little rich for my blood.However i did find all 4 cylinders for $50 and $15 for tools to do it with.I just hope nothing is broke inside.Kit would not work after all that
/ Kubota Boom cylinder leaking #4
When and if I have a leaking cylinder, I take it to a hydraulic shop and have them rebuild it. Some are a bugger to get apart and some require special spanner wrenches as well. Easier to have a shop that specializes in rebuilding - repairing cylinders do it. Much less hassle, least for me.
Building a house right now and money is tight or i would let a shop do it as well.
I believe you will find that you need a complete rebuild kit if you can get it apart, that is.
I watched a couple U Tube videos and besides o rings,there is not much else,but if there is then it gets expensive it appears
Getting it apart was easy but the o ring kit was wrong one.I can't read serial# so i don't know which one to order now
/ Kubota Boom cylinder leaking #11
I rebuilt the bucket, and 2 boom cylinders in my bx2350d. My brother in law tried to pickup an 800lb bale of hay instead of just rolling it. Blew the seals. I changed hydraulic fluid twice after that and was finding blue rubber seal leftovers in the intake screen before the filter. Don't recall the price. The Seals are external on the shaft piston and internal on the nut that the shaft goes through. They are difficult to put in without a special tool. The material the Seals are made of isn't typical oring material. My little hydraulic cylinder shaft nut on the bucket took a breaker bar with a cheater pipe and 34 mm socket to get it off, to change the Seals on the internals of the hydraulic cylinder nut.
It can be done, but if you have large hydraulic cylinders your better off taking it to a hydraulic shop that has the big tools to do it with.
I finally give up and took the hard parts to a reccomended repair shop.It was the best thing.I will never tackle it again
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
(2) 3"X24" HYD CYLINDERS (A60430)
(2) 3"X24" HYD...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
2010 BOBCAT TOOLCAT 5610 UTILITY WORK MACHINE (A59823)
2010 BOBCAT...
2022 CATERPILLAR 249D3 SKID STEER (A60429)
2022 CATERPILLAR...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
