Kubota BH90 backhoe challenges
   / Kubota BH90 backhoe challenges #1
Michael_C
Morgan Hill, California
Kubota L5030,Gearmore
I'm using my 2' wide bucket on the backhoe to dig a 3' wide trench (in two passes). The first pass goes fine, but when I try to take a second pass cutting a 1 foot wide swath, the bucket tends to veer off to the side, and pulls the tractor (Kubota L5030) out of position. The stabilizer pads have four holes, and I wondered if taking advantage of the holes and mounting short bolts to try to gain traction would be a good idea, or present it's own set of problems. I'm working in clay soil, and noticed the cleats were completely packed in - I cleaned them out, but expect them to cake up fairly quickly.
Anyone have a similar experience and find a good solution, or tried using the bolt holes and experienced issues?
   / Kubota BH90 backhoe challenges #2
I would dig all three feet wide simultaneously. Will save you time and require less moving of the tractor. If you've already completed the 2' wide part, this advice is no help.
I am not sure if you're saying to go with a 3' bucket, or whether to take a 2' bite, then the remaining 1' bite and repeat the process until I go the desired depth, and then advance the tractor. The 2' bucket is my widest bucket.
I am digging 3' wide before advancing the tractor. I have marked a line on the dirt on the right side of the trench. My first cut is with the right side of the bucket on this line, and second cut is the remaining 1'. Half the bucket width is doing the work when I'm doing the 1' remaining cut, which causes the bucket to veer towards the right (where the 2' cut had previously been made). If the cleats on the stabilizer pads weren't packed with clay, they would dig in better, and the tractor wouldn't be pushed to the side.
That's why I wondered if I added four bolts per stabilizer pad would help the situation, or just create a new problem.
   / Kubota BH90 backhoe challenges #4
This is a function of having more backhoe than tractor is this particular set of circumstances.
What I mean is, the hoe i strong enough to drag the tractor and the tractor is light enough to get drug around instead of force the bucket through the soil.
Your best solution is to take smaller 'bites'. For example, if your ditch is going to be 18" deep then take 2 bites 9" deep or even 3 bites at 6" deep to get there.
Don't bother trying to 'nail' your tractor to the ground through the stabilizer pad holes or anything like that, it'll just cause you more frustration and leave the ground more tore-up.
Take smaller bites and enjoy the fact that you aren't doing any of the work with a shovel! :)
Good luck,
Mike
Good luck,
Mike
Thanks for the thoughts on using the stabilizer pad holes - Maybe I need to add more weight - looks like a big meal night tonight :~}.
I had reduced the depth of each cut with no big improvement, but will play with it a bit more to see how shallow the cut needs to be to "stay put".
   / Kubota BH90 backhoe challenges #6
If you don't have the rear tires loaded that may help you out a bit.
   / Kubota BH90 backhoe challenges #8
I'd put my 16" bucket on and dig the ditch in two full passes. Obviously 16x2 doesn't equal 36, but it would still work. I can't imagine bolts through those holes would help much.
   / Kubota BH90 backhoe challenges #9
Not sure what you mean?
Sorry, that was worded poorly.
If you load your rear tires it will help keep the backhoe from pulling and pushing the tractor around as much. The extra weight of the fluid near the backhoe really makes a difference in the ability of the machine to bit into the dirt instead of the hoe lifting and pulling the machine.
   / Kubota BH90 backhoe challenges #10
I would try offsetting the tractor so you are digging at a sleight angle. You will have a better bite and it will provide some compensation.
You may also look at the side cutting edge of your bucket.
I have also in some very hard dirt situations had to rake the bucket back and forth with teeth down.
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
2008 Caterpillar 262C High Flow XPS Compact Wheel Loader Skid Steer (A52377)
2008 Caterpillar...
UNUSED RAYTREE RMDM70 - 70" DISC MULCHER (A54757)
UNUSED RAYTREE...
2016 John Deere 326E (A47477)
2016 John Deere...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A55218)
2018 John Deere...
2000 Sterling L9513 Winch Truck (A55218)
2000 Sterling...
