Kubota B7610 quit running
   / Kubota B7610 quit running #1
shear280
Gladwin, MI
B7610
My wife was moving some dirt and the engine stopped. I've checked all the safety switches, no power at the clutch switch. I'm in need of a wiring diagram.
   / Kubota B7610 quit running #2
Welcome to TBN. :)
   / Kubota B7610 quit running #3
Have you checked the pto lever.. my wife hits it all the time..
I have traced the wiring back from the starter to the key switch. The controller 6c190-55512, (new #55513) seems to be the culprit. I need to find out what turns that output on. I have checked all the safety switches for power and continuity. It's tough to trace without diagrams.
   / Kubota B7610 quit running #5
Glad to have you as a member! See you in the forums!!
   / Kubota B7610 quit running #6
Can't help with original problem but would suggest a liberal application of Elecrolitic Grease to all connections as you work your way through checking.:)
   / Kubota B7610 quit running #7
I take it you have check all the fuses,lose +,- wires.
I have checked all the fuses, connections and cleaned and lubed as I went along. I just need to know more about the controller and the wires from that. I don't want to spend $150 for that part until I can track the sensors in to that device.
   / Kubota B7610 quit running #9
I'm sure you checked it but what about the seat sensor?
When you get off it cuts power.
Also this may do better in the Kubota Owner Operator forum.
   / Kubota B7610 quit running #10
Welcome to the forum from Oklahoma.
Ken
(UNUSED) 2024 NEW HOLLAND C332 SKID STEER (A51242)
(UNUSED) 2024 NEW...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
Caterpillar 303.5 (A50120)
Caterpillar 303.5...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
2014 CATERPILLAR 740B OFFROAD DUMP TRUCK (A51242)
2014 CATERPILLAR...
