Kubota B7610 quit running
   / Kubota B7610 quit running #1
shear280
Gladwin, MI
B7610
My wife was moving some dirt and the engine stopped. I've checked all the safety switches, no power at the clutch switch. I'm in need of a wiring diagram.
   / Kubota B7610 quit running #2
Welcome to TBN. :)
   / Kubota B7610 quit running #3
Have you checked the pto lever.. my wife hits it all the time..
I have traced the wiring back from the starter to the key switch. The controller 6c190-55512, (new #55513) seems to be the culprit. I need to find out what turns that output on. I have checked all the safety switches for power and continuity. It's tough to trace without diagrams.
   / Kubota B7610 quit running #5
Glad to have you as a member! See you in the forums!!
   / Kubota B7610 quit running #6
Can't help with original problem but would suggest a liberal application of Elecrolitic Grease to all connections as you work your way through checking.:)
   / Kubota B7610 quit running #7
I take it you have check all the fuses,lose +,- wires.
I have checked all the fuses, connections and cleaned and lubed as I went along. I just need to know more about the controller and the wires from that. I don't want to spend $150 for that part until I can track the sensors in to that device.
   / Kubota B7610 quit running #9
I'm sure you checked it but what about the seat sensor?
When you get off it cuts power.
Also this may do better in the Kubota Owner Operator forum.
   / Kubota B7610 quit running #10
Welcome to the forum from Oklahoma.
Ken
attachment plate (A50322)
attachment plate...
Komatsu WA250-5L Wheel Loader (A52384)
Komatsu WA250-5L...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2013 Jeep Patriot SUV (A50324)
2013 Jeep Patriot...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
