Kubota B2650 & B3350
/ Kubota B2650 & B3350 #41
Seems to be very few 2650 or 3350's out west. I flew 250 miles to see a 2650 today. First impressions:
With cab closed, engine noise was well muffled and hydro whine was not as bad as expected. It is the dominant sound, of course, not overly loud (for a tractor). Fit and finish, especially on the cab was very good. The rest was typical Kubota, which is to say not bad at all.
Now I just have to decide if I want the 26 or the 33. I'll be installing a 62" front mount snowblower and I live almost a mile up, so the 33's turbo and additional horse power would be welcome in the snow, but those extra PTO ponies cost $500 each!
Comments or advice is most welcome.
bumper
/ Kubota B2650 & B3350 #43
62" front blower combined with high altitude, 26hp will most likely lack power in wet/heavy snow situation, it is not a brute, even just for loader work, it could use the extra ponies.
/ Kubota B2650 & B3350 #44
Thanks for the link, though I have previously read it, and most everything else I could find over a few weeks of searching! Honest, I've tried to do due diligence on this (it's a lot of money!). Since the 3350's have only recently started delivery, there's not a lot in the way of reviews . . .
I previously owned a 24 hp Kubota, one of the first HSTs, so am aware of the bogging down thing. However, since these two tractors share the same hydraulic flow and pressure, I was assuming that those systems would behave the same. And the extra horsepower and torque of the 33 would only be apparent in top speed and at the PTO's . . . No?? So I'd think loader and BH bogging down would be the same, but not so with the snowblower driven off the PTO of course.
I am concerned about not having enough HP for the blower with the 2650. Some say the rule of thumb is 5HP for each foot of snowblower width.
bumper
/ Kubota B2650 & B3350 #45
Will non cab models be available on these two units?
/ Kubota B2650 & B3350 #47
Cabless 3350 at GIE expo.
/ Kubota B2650 & B3350 #49
A big part of the reason I ordered a B3350 was the cab. That and the tractor is the right size, as bigger would have presented storage and transportation issues. If I hadn't needed (okay, wanted) the cab, there are a whole lot of other less expensive options in the way of nice low time used tractors out there.
I wonder how well the Bxx50's will do in their cab-less version?
bumper
/ Kubota B2650 & B3350 #50
I'll be interested to learn when these cabless B250's are coming out.
Thanks for posting this.
/ Kubota B2650 & B3350 #51
Thanks to all the information I found on this site and thread, I ordered a B2650 cab and get it in two weeks! I was "afraid" of all the issues with the tier 4 and the 3350...I will keep you all posted! Thanks!!!
/ Kubota B2650 & B3350 #52
When considering the two models - even though the larger version has more HP - some of that power will be lost with the fuel soaking DPF muffler - all in all the best bet is the 2650 you get a clean engine and you have $5k for fuel or goodies to hang on the beast. I have a B21 and while it does not have ton's of power, its fine and will dig like crazy.
/ Kubota B2650 & B3350 #53
When considering the two models - even though the larger version has more HP - some of that power will be lost with the fuel soaking DPF muffler - all in all the best bet is the 2650 you get a clean engine (new 4 cylinder) and you have $5k for fuel or goodies to hang on the beast. I have a B21 and while it does not have ton's of power, its fine and will dig like crazy.
Not arguing about which is best, but to keep the record straight:
The B2650 has a 3 cylinder engine while the B3350 has a 4 cylinder engine (bore and stroke is the same).
The B3350 does have the "nasty" DPF, but it has a turbo to make up for the DPF power loss. This may be more important if you live at a higher altitude as a normally aspirated engine looses 3% per thousand feet.
So I'd say it depends on one's circumstances as to which is the better choice.
bumper
/ Kubota B2650 & B3350 #54
Save $5,000 and get a clean engine without all the electronic crap - there's little to think about!
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
VALMAR AIRFLO 8600 PULL TYPE FERTILIZER SPREADER (A60430)
VALMAR AIRFLO 8600...
Electric Golf Cart (A56859)
Electric Golf Cart...
2014 Nissan Murano SUV (A59231)
2014 Nissan Murano...
