Item Details
- Listing Type
- Auction
- Stock ID
- 55315
- Make
- Kubota
- Type
- Tractor
- Year
- 2022
- Seller
- Fastline Auction, LLC
- Model
- 2610
- Location
- Florida
- Horsepower
- 24
Description: 2022 Kubota LX2610SU Compact Utility Tractor. The Kubota LX2610SU is a compact tractor with a 24.8-gross-horsepower engine, 19.5 PTO horsepower, and a 3-range hydrostatic transmission. Key features include a standard LA535 loader with a 1,067 lb lift capacity, 4WD, a 2,139 lb 3-point hitch lift capacity, and an open station with a roll-over protective structure (ROPS). It is a value-focused model designed for tasks like land maintenance and material handling. Engine and power PTO Horsepower: 19.5 hp Engine: 1.3L, 3-cylinder, liquid-cooled diesel PTO: Standard rear and mid PTO Transmission: 3-range hydrostatic (HST) with 4WD Gross Engine HP: 24.8 hp Hydraulic system Hydraulic Pump Flow: 8.7 gpm Loader Lift Capacity: 1,067 lbs 3-Point Hitch Capacity: 2,139 lbs at the lift point Physical specifications Operating Weight: 1,786 lbs Ground Clearance: 14.6 inches Operator station Type: Open station with ROPS Features: Flat, wide operator's station with rubber mat, comfortable seat, and side-mounted loader joystick Brakes: Multi-plate wet disc Steering: Hydraulic power steering FASTLINE SALES REPRESENTATIVE(s) Nick Herring nick.herring@fastline.com 919-922-2854 Make: Kubota Model: LX2610SU Year: 2022 Serial No.: KBUB8AHRVN1G29779 Hours: 5 Meter Reads: 5 Horsepower: 24.8 Transmission: Hydrostatic Absolute: No Condition: New Enclosed Cab: No Stock No.: E79427 Item Location - Address: Provided by Seller Item Location - City: Brandenton Item Location - State/Province: Florida Item Location - Postal/Zip Code: 34212 Item Location - Country: United States
This is a online bidding auction by Fastline Auction, LLC
2022 Kubota LX2610SUHSD Compact Utility Tractor
see lot description, multiple locations, KY 40010
Starting Bid: 5500.00 USD
Auction Finishes: November 18, 2025 at 04:10 PM
Click Here To Bid Now!
Happy Bidding!
Happy Bidding!
