Kubota B2650 & B3350
/ Kubota B2650 & B3350 #41
Seems to be very few 2650 or 3350's out west. I flew 250 miles to see a 2650 today. First impressions:
With cab closed, engine noise was well muffled and hydro whine was not as bad as expected. It is the dominant sound, of course, not overly loud (for a tractor). Fit and finish, especially on the cab was very good. The rest was typical Kubota, which is to say not bad at all.
Now I just have to decide if I want the 26 or the 33. I'll be installing a 62" front mount snowblower and I live almost a mile up, so the 33's turbo and additional horse power would be welcome in the snow, but those extra PTO ponies cost $500 each!
Comments or advice is most welcome.
bumper
/ Kubota B2650 & B3350 #43
62" front blower combined with high altitude, 26hp will most likely lack power in wet/heavy snow situation, it is not a brute, even just for loader work, it could use the extra ponies.
/ Kubota B2650 & B3350 #44
Thanks for the link, though I have previously read it, and most everything else I could find over a few weeks of searching! Honest, I've tried to do due diligence on this (it's a lot of money!). Since the 3350's have only recently started delivery, there's not a lot in the way of reviews . . .
I previously owned a 24 hp Kubota, one of the first HSTs, so am aware of the bogging down thing. However, since these two tractors share the same hydraulic flow and pressure, I was assuming that those systems would behave the same. And the extra horsepower and torque of the 33 would only be apparent in top speed and at the PTO's . . . No?? So I'd think loader and BH bogging down would be the same, but not so with the snowblower driven off the PTO of course.
I am concerned about not having enough HP for the blower with the 2650. Some say the rule of thumb is 5HP for each foot of snowblower width.
bumper
/ Kubota B2650 & B3350 #45
Will non cab models be available on these two units?
/ Kubota B2650 & B3350 #47
Cabless 3350 at GIE expo.
/ Kubota B2650 & B3350 #49
A big part of the reason I ordered a B3350 was the cab. That and the tractor is the right size, as bigger would have presented storage and transportation issues. If I hadn't needed (okay, wanted) the cab, there are a whole lot of other less expensive options in the way of nice low time used tractors out there.
I wonder how well the Bxx50's will do in their cab-less version?
bumper
/ Kubota B2650 & B3350 #50
I'll be interested to learn when these cabless B250's are coming out.
Thanks for posting this.
/ Kubota B2650 & B3350 #51
Thanks to all the information I found on this site and thread, I ordered a B2650 cab and get it in two weeks! I was "afraid" of all the issues with the tier 4 and the 3350...I will keep you all posted! Thanks!!!
/ Kubota B2650 & B3350 #52
When considering the two models - even though the larger version has more HP - some of that power will be lost with the fuel soaking DPF muffler - all in all the best bet is the 2650 you get a clean engine and you have $5k for fuel or goodies to hang on the beast. I have a B21 and while it does not have ton's of power, its fine and will dig like crazy.
/ Kubota B2650 & B3350 #53
When considering the two models - even though the larger version has more HP - some of that power will be lost with the fuel soaking DPF muffler - all in all the best bet is the 2650 you get a clean engine (new 4 cylinder) and you have $5k for fuel or goodies to hang on the beast. I have a B21 and while it does not have ton's of power, its fine and will dig like crazy.
Not arguing about which is best, but to keep the record straight:
The B2650 has a 3 cylinder engine while the B3350 has a 4 cylinder engine (bore and stroke is the same).
The B3350 does have the "nasty" DPF, but it has a turbo to make up for the DPF power loss. This may be more important if you live at a higher altitude as a normally aspirated engine looses 3% per thousand feet.
So I'd say it depends on one's circumstances as to which is the better choice.
bumper
/ Kubota B2650 & B3350 #54
Save $5,000 and get a clean engine without all the electronic crap - there's little to think about!
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
16in. Skid Steer Track (A65640)
16in. Skid Steer...
2024 BOBCAT S76 R-SERIES SKID STEER (A65053)
2024 BOBCAT S76...
John Deere 5000-Series Tractor Grill Guard (A65640)
John Deere...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
2022 EZ-GO ELITE...
