Kubota B2410 Specs
/ Kubota B2410 Specs #1
Knight9
Alberta
Kubota B2410 with turfs
Hi all,
I'm doing the compare between New Holland, Kubota, John Deere and Massey Ferguson. Got the "glossies" for all except the Kubota I'm looking at and the dealer was closed (on a Saturday??). Can anyone tell me a few specifics I'm trying to compare on?
On the B2410 what is the weight of the base tractor (believe that is defined with ag tires)? What is the implement hydraulic pump capacity in gpm? What is the steering pump capacity in gpm? And finally what is the lift capacity of the 3PH. Think I've got all the rest of the details I was looking for.
This exercise would not be necessary, but my Cub dealer has "gone under" and without service/parts I will be making a change over immediately.
Thanks in advance.
Kevin
/ Kubota B2410 Specs #2
Kevin, I don't know the answers, but have you looked at http://www.kubota.com? I think you'll find most of the answers there by going to "products", pick the one you want and go to "specifications".
Bird
/ Kubota B2410 Specs #3
Kevin,
I also looked at the B2410. It's a nice machine though I forgot the specs. I would strongly encourage you to drive each tractor at least twice!! You might think that you are pestering the dealer but it is his job. You want to be comfortable with this purchase. I drove a 2710 and a L3010 multiple times. One of my main concerns was comfort and leg room. Try em, try em, try em. Even if it's just a short trip through the parking lot.
Peter
Hi Bird,
Yes, I have indeed looked at Kubota's web site. Unfortunately, I found it rather lacking as far as spec sheets. All of the others had very detailed specs listed on their pages, but Kubota only listed engine type, horse power, width, length, clearance and a few other items. I could not find any specific info on the hydraulics or some of the other items.
Guess I'll have to wait to get the glossy pamphlets from the dealer for the nitty-gritty details.
Thanks,
Kevin
Hi Peter,
I certainly agree with you. We would never buy a car or truck without a test drive...and a tractor is as much money!!! The only one I test drove today was a JD 4300. Nice machine. Might be hard to test drive a Kubota though. The dealers here are really back ordered. Not sure if I can wait till they get their order in (March). But if the spec sheets tell me that for the money the Kubota appears to be the best machine, then I'll hold off for sure to drive it before I go with any of the others.
Thanks,
Kevin
/ Kubota B2410 Specs #6
Sorry about that, Kevin. 'Tis a sad fact that the specs on kubota.com are greatly lacking in detail.
Bird
/ Kubota B2410 Specs #8
Kevin,
Darn, I have the "Glossy" from my shopping days and also very fat fingers, but here goe's.
PTO HP 18
Engine Gross HP 24
Rated RPM 2600RPM
Fuel Tank 6.3 Gal
Cooling system 4 Qt
Engine oil 3.2 Qt
Tran. Case 3.3 Gal
Transmission HST (2 range)/ Gear(6 fwd, 2 Rev)
Diff. Lock Standard
Final Drive Spur
Brake Wet Disc
PTO Gear/Transmission driven with one way clutch
PTO Rear 540 RPM
PTO Mid 2500 RPM
Hydraulics Open Center
Pump Dual Pump
Pump 7.0 GPM
Hyd outlet Front/Rear
Three Point Hitch Cat 1
Position Control Standard
Lift Cap. @ Lift Point 1655 lbs
Lift Cap @ 24' Behind LP 1300 lbs
Steering Power
Tire Front 4WD 7-12 2WD 6.50 -10
Tire Rear 11.2-16
overall length 91.7in.
overall width 46.3 in.
Weight with ROPS HSE 1367, HSD 1477,HSDB 1500
Whew!!!
Al
Hi Al,
What...is that all you could come up with?? /w3tcompact/icons/wink.gif Seriously, thank you very much. That has almost completed my spreadsheet. Now I can have a decent comparison between the 4 machines I'm looking at.
The one real surprise you listed there is the weight of the tractor. I had no idea that the B2410 would be 1000 lbs lighter than the TC25 and the JD 4200. That seems like a lot of difference for "same class" machines?? Mind you the MF 1230 is listed at 1720 lbs...not too far off.
Thanks again for your quick assistance. Now it is time for decisions!! If I could post a copy of my completed spreadsheet I would. Might help out some others who could use seeing the comparison matrix in black and white.
But as Bird, and others, have pointed out many times before, the paper means nothing if the tractor isn't comfortable for you and doesn't feel good!!! Guess the combination is what we are all looking for.
Kevin
/ Kubota B2410 Specs #10
Kevin,
I like a guy that shops with a spread sheet./w3tcompact/icons/wink.gif
I don't know for sure why the NH comes in heavier, but I believe they do. I also believe the Kubota is an honest no tires filled number. The Deere numbers are with the tires filled.
I didn't realize that JD's numbers were with filled tires. The specs say "field ready"....which I guess really could mean anything.
Must say though, that so far my spreadsheet is telling me to lean towards the TC25D...have to wait to see how all those test drives go!
Kevin
/ Kubota B2410 Specs #12
Hi Kevin,
I'm also looking at the B2410HSD - just got a price today as a matter of fact. One comment: I wouldn't really say that the 4200, TC25, and B2410 are all in the same class. In fairness, while the gross HP numbers are nearly the same, the physical size is quite a bit different. The 4100, TC21, B7500, and B2410 all have the same wheelbase (59"), and nearly identical total lengths (about 8.5'). The wheelbase and length of the 4200 and TC25 are about 6" and 1' longer, respectively. It doesn't sound like much, but if you put the two different "sub-classes" of machine side-by-side, you see a pretty big difference. I looked at a TC25 next to a TC21 and thought "Sheesh - I can't mow with THAT thing". I like the B2410 because it packs the most power into the smallest available frame size, which is important since I will use it to mow.
On weights: There is a long thread somewhere in the archives about the exact meaning of the Kubota quoted weights. It will make your hair hurt but everyone should read it once. The jury may still be out, but my guess is the B2410 with Ag tires probably weighs about 1800 lb (the TC21 and 4100 are quoted at around 1550 lb). The 4200 and TC25 on the other hand are quoted at 2500+ lb.
Too much information probably, but I hope some of it helped.
- Rob
Hi Rob,
Thanks for the thoughts. Your statement about not including the B2410 with the TC25/4200 in a straight comparison are probably very accurate. In fact, the B2410 is the only one of the 4 (including the MF1230) that I have not physically seen or sat on. Thus I really have nothing to compare....which pretty much makes the compare impossible other than attempting to check specs. Once I can see it in person and drive it, I'm sure the difference will be obvious.
And really, 1000 lbs of extra weight is great for scraping snow or tilling a garden, but not so great for mowing a damp lawn!! Unfortunately, don't think I can put that in my spreadsheet /w3tcompact/icons/wink.gif.
Kevin
/ Kubota B2410 Specs #14
Factory List: $14,280.
Specifications for the Kubota B2410HSD Tractor
Engine
Model D1105-E-D16
Type Indirect Injection Vertical, water cooled, 4 cycle diesel
Number of cylinders 3
Total displacement (cu-in.) 68.5
Bore and stroke (in.) 3.07 X 3.09
Gross engine horsepower 24.0
Power take off horsepower 18
Maximum torque (ft. lbs.) 50
Capacities
Fuel tank (U.S. gallons) 6.3
Engine crankcase (with filter, qts.) 3.2
Engine coolant (qts.) 4.0
Transmission (gallons) 3.3
Dimensions
Overall Length (without 3 point hitch, inches) 91.7
Overall Width (at minimum tread setting, inches) 46.3
Overall Height (with ROPS, inches) 77.4
Wheel Base (inches) 59.0
Minimum ground clearance (inches) 12.8
Weight (with ROPS, lbs.) 1477
Drive Train
Front tire size (standard) 7-12
Rear tire size (standard) 11.2-16
Clutch Dry type, single stage
Steering Integral power steering
Transmission Hydrostatic transmission with 2 ranges
Control type "Rocker" pedal for forward-reverse
Brakes Wet disc type
Minimum turning radius with brakes (ft.) 6.9
Hydraulic System
Hydraulic control type Position type control
Pump capacity (gallons per minute) 4.4
Three Point Hitch Category 1
Maximum lift capacity at lift points (lbs.) 1655
Maximum lift capacity at 24" behind lift point (lbs.) 1300
Power Take Off
Rear PTO type SAE 1 3/8", 6 spline with overrunning clutch
Rear PTO speed 540 RPM @ 2600 engine RPM
Mid PTO type USA #5, 10 spline involute
Mid PTO speed 2500 RPM @ 2578 engine RPM
/ Kubota B2410 Specs #15
Please be very careful while "studying the spec. on paper."
They are very important but can be seriously misleading to "first time shoppers."
The minor differences between one brand or another (or one model or another) may have nothing to do with the goals you have set for the tractor at YOUR HOME or RANCH. Indeed, often times a tractor with certain lesser specs. may better perform the task you have in mind.
HP, lifting capacities, engine cu. in.s, etc. must be understood fully and how they'll apply to your particular situation.
I have found that the "standard equipment" issues are specifically more important to the first time shoppers.
The type and quality of operator seats, cushioned platforms, steering, PTO features, lighting, grille guard, joystick control valves, three point hitch components and stabilizers are ALL UP FOR GRABS when the seal is struck. The "delivered final package" with or without all the standard equipment is the main thing the shopper should be focused on.
We provide this web-service that is being used by shoppers and our fellow/competeive dealer sales teams:
Start here at the Kubota Tractor, main menu:
http://www.carverequipment.com/tractor_menu_page.htm
Then click on the model you are considering for general information and links for the details and tips.
Example: Tractor Model (B2410 example)
http://www.carverequipment.com/b2410_intro.htm
Link - You'll find detail specifications, and weights and measurements (with and without loaders)
http://www.carverequipment.com/b2410_weights_and_measures.htm
Link - You'll find detail information about the standard equipment offered on each model.
http://www.carverequipment.com/extra/b2410_hsd__standard_equipment.htm
Link - http://www.carverequipment.com/new_b2410_order.htm
A complete list (with pricing guidelines) for the tractors, tires, loaders and scores of options with photos.
We invite to use these pages as often as you'd like. We believe that the better informed shopper make the best "Value Decisions." We'll appreciate your advise and notes when you find typo's or do not find info you'd like to see on the webpage.
Good luck and happy shopping.
Steve
Thank you Steve for the web pages and information. I will be sure to check them all out. Unfortunately being from Alberta, the costs posted (in USD) are rather irrelevant to me. But the specs and "standard equipment" lists will be great.
I appreciate it.
Kevin
/ Kubota B2410 Specs #17
hello you. Could you tell me what GAP should have the valves in kubota b2410 to configure them;;
Wow! This is resurrecting a very old thread I see. :)
Unfortunately, I can't answer your question, but I would suggest maybe getting your hands on the B2410 shop service manual. There are various vendors online that you can purchase from.
Good luck!​
/ Kubota B2410 Specs #19
Kevin,
PTO HP 18
Engine Gross HP 24
Rated RPM 2600RPM
Fuel Tank 6.3 Gal
Cooling system 4 Qt
Engine oil 3.2 Qt
Tran. Case 3.3 Gal
Diff. Lock Standard
Final Drive Spur
Brake Wet Disc
PTO Rear 540 RPM
PTO Mid 2500 RPM
Pump Dual Pump
Pump 7.0 GPM
Steering Power
Tire Rear 11.2-16
Whew!!!
Al
Does anyone know the weight of this tractor with the FEL? I need this information to decide what size trailer to get.
/ Kubota B2410 Specs #20
Just guessing, but it will probably be somewhere between 2,000 and 2,500 lbs for tractot + FEL. Any ballast, implements, other stuff would be additional.
You'll want a safe margin on axle capacity and enough length to allow proper balancing.
RDS Manufacturing 70307 48 Gallon L-Shaped Transfer Diesel Fuel Tank (A59230)
RDS Manufacturing...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59904)
2019 INTERNATIONAL...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
2016 American Eagle Reel Trailer (A60352)
2016 American...
Tiffin Class A Motorhome (A59231)
Tiffin Class A...
2019 CHEVROLET SILVERADO 11FT FLATBED (A59905)
2019 CHEVROLET...
