kubota 900
/ kubota 900 #1
troe
pontiac il.
tn75
i have owned the 900 for a few years, i could not stand to be with out it, just think its the best thing since the tv.. but my fuel gage and temp gage both stoped working, anybody have any ideal that i could check to correct the problem? have check fuses,i keep thinking its got to be a ground?
/ kubota 900 #3
We have many rtv owners here. I hope one will chime in and assist you.
You shouldn't have to go elsewhere.. :eek:
BTW Welcome to Tractorbynet.
/ kubota 900 #4
Wow, didn't know Kubota made a temp gauge that ever worked.
Just the usual, fuses, ground and power wire, the gauges themselves.
/ kubota 900 #5
Feeling low on fuel? just tap the gauge a few times it'll fill right up....mine does.
Fuel gauge stopped working about the time the temp gauge started working.
With all thats right on the RTV balky gauges is a small thing. I'll replace them sooner or later I guess.
D
/ kubota 900
thanks for the reply, temp gage is working, plowed snow last day or so and finally got the temp gage to move, but the fuel gage is not, may take out and get a new one and see if that works, anybody know what the cost of a gage is?
/ kubota 900 #7
On your fuel guage, check for the ground or the connector on top of the tank...
Even if you have to replace the guage, it don't cost enough to even talk about.
/ kubota 900
i did give the old wiggel the wire on the tank and gage. but i will look it over in the morning. thanks for the advice.
/ kubota 900 #9
Surprized that since you owned it for a few years your dealer has not replaced them or inquired as to how they were working?
In the beginning, when man made the RTV, a fog descended upon the gauges, but all was not lost. Whilst other men fretted and wondered on heat and fuel, the men of orange offered replacements to the haze.
Anyway, jiggle away. My temp gauge takes a long time to "heat up" and well. the diesel mileage is fantastic. But they do work...just slowly....
-Mike Z.
/ kubota 900 #10
Hey tom r, I have an intimate relationship with the RTV900 gauges. For months after getting my new RTV900 back in early '04 I got to enjoy seeing two milky white orbs looking at me from the dash after about 1/2 an hour of operation. Kubota promptly replaced those with gauges that fogged up in only 20 minutes. After letting them know about that, they again promptly replaced those gauges with ones that took nearly 35 minutes to fog over. After that, I gave up.
Anyway, I discovered that after several months of use the gauges stopped fogging over. If I'm not mistaken I still have one set of gauges left over for the RTV900 that were replaced because they fogged over. Being that they are a few years old now, they may have lost their internal moisture and no longer fog over. They worked fine, but got foggy. If you are in need, and the '04 gauges would fit your RTV, just let me know.
/ kubota 900 #11
I just replace the fuel gauge last year, $32 and change.
/ kubota 900
thanks for the offer of your 04 gages, and thanks for the price input, i think i will call my local kubota dealer and see if they have one on hand and try a new one. i think my 900 is a o4, that is the only problem i have had since buying it in 04, i do wish i had some doors for winter, ben thinking about trying to build some?
/ kubota 900 #13
I got the second 900 the dealer got in. I've had several problems but Kubota took care of them. They replaced all the tires and wheels, new hood (something to do with it coming loose) on recall and then the hydrulic tank bracket broke on the back . All having to do with the first ones out I imagine. It is built like a tank and works like a tractor. Still have a problem with changing gears if you stop while under a load.
/ kubota 900
i almost forgot, one problem i am having is the fuel cap or tank, can not hardly get the cap to screw on or off. do not know if its the tank or cap?
/ kubota 900 #15
There is a tech service bulliten out on that fuel cap. Kubota replaced my free of charge and your dealer has to do the same. The new style cap has printed on "diesel only or fuel". This is how they tell if it has the newer style cap.
/ kubota 900 #16
If that doesn't work out, the offer is still there for the gauge I have. Your cost would only be the cost for shipping. Hope all works out okay for you.
/ kubota 900
thanks for the offer , sure is nice to have such a nice group of people to talk about rtvs, i will let you know about the fuel gage. thanks for all the help
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
1 PALLET OF HYDRAULIC HOSES (A66091)
1 PALLET OF...
2016 CAT 308E2CR EXCAVATOR (A67714)
2016 CAT 308E2CR...
2021 JOHN DEERE 304L WHEEL LOADER (A65056)
2021 JOHN DEERE...
THE MACHINE CO. THAWZALL H250 HEATER TRAILER (INOPERABLE) (A67714)
THE MACHINE CO...
