JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 4,122
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
LD1 said: IF you start the tractor up, and raise the 3PH lever, then immediately (before the 3PH implement is raised all the way) you grab and raise the loader, the 3PH will "pause" its lift while raising the FEL. Once you are done raising the FEL and let off the stick, the 3PH will resume its raise.
Yep. That is exactly what I said. It is one track mind hydraulics. You are moving under hydraulic power only one thing at a time. I did not realize the MX lacked a separate pump for the 3PH. My MF2660 has a separate 3rd pump for the 3PH.
LD1 also said "It goes Pump > Loader Valve > Remotes > 3PH." They are all open center and when you move a lever to open flow for any one of them then the others wait. In your example your raising the loader forced the 3PH to wait. I am puzzled how the pecking order (priority) is established however.
