Kubota 26L engine
/ Kubota 26L engine #1
2458n
Does this engine have any history? Good or Bad please.
/ Kubota 26L engine #2
Kubota engines start with a Z for 2 cylinders, a D for 3 cyls., V for 4, F for 5, and S for 6 cylinders, followed by an approx cc displacement. Typically this number is stamped on the top of the block near the injection pump on older engines and on a pad under the exhaust manifold on newer engines.
Brian
/ Kubota 26L engine
Thank you Brian for the correction. The tractor has a 6 in it. the machine is a M model. M4500DT with 3400 hours. Anything to look out for?
/ Kubota 26L engine #4
I will assume then that it is an S2600. There isn't anything out of the ordinary I would look for. 3000 hrs is not that many if it was reasonably cared for. I'd look for any exhaust smoking and excessive blow-by, along with how easily it starts.
/ Kubota 26L engine
Again thank you for your input. How can they talk about outlawing gambling on line. Anyone looking for equipment on line is certainly in that same area.
