Kubota 26L engine
/ Kubota 26L engine #1
2458n
Does this engine have any history? Good or Bad please.
/ Kubota 26L engine #2
Kubota engines start with a Z for 2 cylinders, a D for 3 cyls., V for 4, F for 5, and S for 6 cylinders, followed by an approx cc displacement. Typically this number is stamped on the top of the block near the injection pump on older engines and on a pad under the exhaust manifold on newer engines.
Brian
/ Kubota 26L engine
Thank you Brian for the correction. The tractor has a 6 in it. the machine is a M model. M4500DT with 3400 hours. Anything to look out for?
/ Kubota 26L engine #4
I will assume then that it is an S2600. There isn't anything out of the ordinary I would look for. 3000 hrs is not that many if it was reasonably cared for. I'd look for any exhaust smoking and excessive blow-by, along with how easily it starts.
/ Kubota 26L engine
Again thank you for your input. How can they talk about outlawing gambling on line. Anyone looking for equipment on line is certainly in that same area.
2015 Peterbilt 320 T/A McNeilus Front Loader Garbage Truck (A64556)
2015 Peterbilt 320...
2016 VOLVO SD115B SMOOTH DRUM ROLLER (A65053)
2016 VOLVO SD115B...
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
2010 Chevrolet Tahoe SUV (A64194)
2010 Chevrolet...
KUBOTA SVL97-2 SKID STEER (A65053)
KUBOTA SVL97-2...
