Korean tractor dilemma
   / Korean tractor dilemma #151
Called dealer. 2 weeks and they havnt even looked at it. I bought the unit out of state, this dealer was the only one i could find to work on it. The other wouldnt touch it, there work shop is an old barn you can look through.
For giggles i called the largest ls dealer in the US and gave them the part # for the hst pump. Couldnt get me a price or availability. Said if the warehouse had it in stock it would take a month to get and if it had to come from korea would take 2 months.
I can see this turning into a s*** show quick
I believe I pointed the parts supply issue out as a weakness of all the non-power 4 brands.
BTW, if you need older Kubota parts, it's the same story. Had a brass fuel return fitting, banjo bolt, and something else, that had 90 day lead time, and after 85 days, they canceled the order... Luckily, I was able to come up with a combination of essentially "off the shelf" parts to make it work.
   / Korean tractor dilemma #152
I wonder what the rear attachment points on your tractor actually looks like? Or do they just put the 2 hole balls in the lower arms?
Our tractors are basically the same weight, and 3pth lift but mine is only cat 1, so I wonder if a cat 1/2 3pth tractor rear end has wider lower arm attachment points, or a higher top link attachment point? I guess no one cares as long as it doesn't break off the tractor.
My tractor is cat 1 3pth, but I'm using an old 1000+lb box blade which had wallowed out cat2 clevis lower arm attachments which initially I just made some bushings to use my Cat 1 pins without much slop, and later welded the bushings into the clevis's, and it seems to work great behind my tractor.
I assume all heavy duty 3pth attachments use clevis's anyways? Cat 1 lower pins are a bit of a weak spot I find, or maybe I need a bigger cheater bar when I tighten them... They seem to come loose or bend on my light duty stuff...
I haven’t compared them but I assume that the arms have a wider spread. The pins are 1 1/8” instead of 3/4”.
   / Korean tractor dilemma #153
You can hear all about the JD tractors of years ago how
good and reliable they are guess who made them YANMAR
I do believe that YANMAR is the only tractor with the 10 year warranty. They also have some nice discounts going
on now.
willy
   / Korean tractor dilemma #154
Not familiar with the smaller LS, but the 3 series LS is the equivalent of my 4820 TYM. Those LS models do lift about a foot less.
I looked real hard at the 3 series before my purchase. Dealer was close and knows tractors. For the money, it was a lot of tractor, but like you said lift height is short. Also, I was just worried to much about parts availability and will he be there in 5 years. Might not be an issue but gave me pause.
He also had an MT468 that I really liked. If I had bought a Korean tractor it would have been one of the above.
   / Korean tractor dilemma #155
Never really messed with a LS machine, the dealer got bought out and shut down locally; But from a quick walk around, they seemed well built, on par with Kioti/Kubota/Massey. I know TYM has a lot of fans, and frankly, for the 35-60 hp compacts, they probably are the most machine for the money; but they didn't seem as refined as the others, to me. That's just visual/comfort, and 100% subjective. Even with that, they have more comforts then a 15 year old Kubota of similar size.
I know everyone preaches that they want simplicity, but the truth is, a good seat, ergonomic loader joystick, cup holder, entry steps, ect; are nice to have.
   / Korean tractor dilemma #156
Banjo bolts are normally metric thread. So if you have access to a drill press, you can make one yourself.
I've done this a couple of times with older deutz engines where someone robbed one off the engine, and it would take 3 months to get one shipped from Germany.
   / Korean tractor dilemma #157
Perfectly happy with my LS MT3, which I guess in everyone’s opinion is a POS with low lift height.
The weld quality on the tym was down right pitifull. Cold lap, under cut, craters, spatter, wire stubs. Thing was just down right terrible.
   / Korean tractor dilemma #159
I will agree on that part. Some of the welds were not pretty. That is one reason I bought the Branson. The fit and finish was a bit better.
   / Korean tractor dilemma #160
I prefer buying S Korean over Japanese. The S Koreans never bombed Pearl Harbor. The S Korean industrial machine is blossoming, while the Japanese industrial machine is dying. The Japanese workforce is aging, and the new generation of workers is inferior in every metric.
2004 MACK CX VISION (INOPERABLE) (A52472)
2004 MACK CX...
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
2013 FOREST RIVER (A52472)
2013 FOREST RIVER...
2008 Nissan Sentra Passenger Car (A51694)
2008 Nissan Sentra...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
