Oil & Fuel Kohler 30KW standby generator
   / Kohler 30KW standby generator #51
Guardian must be cabbaging parts from Kohler. My 17KW vapor fired Guardian V twin has the exact same cooler pictured in your PDF file. It holds 2.5 quarts with the oversize oil filter and it still uses oil but as I stated previously, all engines use oil and I suspect it gets pretty warm in the enclosure anyway.
Our standby is primarily for my wife's contentment, not mine. If I had my druthers, I'd have a Caterpillar or Onan diesel powered standby unit, skid mounted in the shop that would run everything plus the neighbors.
I much prefer diesel exhaust over propane.....:)
Having a genset that smells like a forklift running leaves something to be desired......
   / Kohler 30KW standby generator #52
I am considering a 30KW home standby generator. I have eliminated Generac and Kohler from my list because they both use a lightweight overhead cam GM engine with a timing belt running at 3600 RPM. I will not buy a GM overhead cam timing belt engine. Instead, I am considering generators using the old cast iron GM 3.0L engine that runs at 1800 RPM.
Bill
   / Kohler 30KW standby generator #53
....I've eliminated GM-Government Motors from my vocabulary entirely the whole caboodle.
   / Kohler 30KW standby generator #54
Bill
That's interesting, any other specs, brands, links???
JB
   / Kohler 30KW standby generator #55
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2017 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2015 Peterbilt 567 (A55973)
2015 Peterbilt 567...
2022 Club Car Tempo Golf Cart (A55853)
2022 Club Car...
2017 BX2680 Sub Compact Utility Tractor (A56435)
2017 BX2680 Sub...
Deere 35P (A53317)
Deere 35P (A53317)
