dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,798
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
Steverino said:I am thinking of simply just fixing it myself.
That has been my inclination, too. The fix I envision is a rectangular
piece of 1/2" steel plate with a rectangular hole cut into it. I would
make this as large as will fit INSIDE the cross-tube. The rectangular
hole would be slightly smaller than the existing access hole in the tube.
I would weld on nuts to the inside of the piece so the access hole
cover bolts can be torqued tight. My reinforcement would be welded
in. This should add stiffness to the cross-tube and minimize the
weakness that the access hole causes. Furthermore, the reinforcement
adds a couple of pounds AND it does not change the dimensions of
the cross-tube. No re-painting, either. My homemade CK30 grille guard
comes very close to the existing access hole cover and any additional
thickness here would rub same. The factory grille guards on my other
units do not have this problem.
