KL 120 & 130 loader issue FIX READY
/ KL 120 & 130 loader issue FIX READY #21
Steverino said:
I am thinking of simply just fixing it myself.
That has been my inclination, too. The fix I envision is a rectangular
piece of 1/2" steel plate with a rectangular hole cut into it. I would
make this as large as will fit INSIDE the cross-tube. The rectangular
hole would be slightly smaller than the existing access hole in the tube.
I would weld on nuts to the inside of the piece so the access hole
cover bolts can be torqued tight. My reinforcement would be welded
in. This should add stiffness to the cross-tube and minimize the
weakness that the access hole causes. Furthermore, the reinforcement
adds a couple of pounds AND it does not change the dimensions of
the cross-tube. No re-painting, either. My homemade CK30 grille guard
comes very close to the existing access hole cover and any additional
thickness here would rub same. The factory grille guards on my other
units do not have this problem.
/ KL 120 & 130 loader issue FIX READY #22
dfkrug, your idea is what I had also invisioned. Engineers think alike. I believe that idea of a fix would be even stronger than what Kioti has designed. I do believe that a 3/8" plate would be fine as long as it was as wide as possible around the perimeter. I believe placing it on the outside, if clearance was not a problem, and welding the outside perimeter would give it more strength. I think Kioti just didn't want the dealers to have to do the welding job or have it sent out to a weld shop. A bolt on part is easier but I'm not to excited about those jack bolts. Now you have just created different stress points. As Steverino mentioned, additional maintenance to check the bolts and if service to the hydraulic lines is needed, then it all comes off.
/ KL 120 & 130 loader issue FIX READY #23
If welded steel cracked under the flex of the FEL then how do they expect us to believe boxing it in and clamping it with bolts can resist the same stress. Out of sight out of mind doesn't stop the cracks from growing. It's just harder to see the cracks under the extra plates and all those bolts.
/ KL 120 & 130 loader issue FIX READY #24
It's my understanding this 'fix' was subjected to many hours of actual use before being approved for production. I guess we could all be arm chair quarterbacks and speculate about the end result. I'm glad Kioti followed through, included all the FEL's within the serial number sequence, wether cracked or not. ...and I applaud our TBN participating Kioti dealers for keeping us informed.
Oh, BTW....dig'em welcome to TBN.
Don
/ KL 120 & 130 loader issue FIX READY #25
I guess I am willing to believe that the new cover and clamps will stiffen the torque tube and thereby reduce the stress on the corners of the inspection hole where the cracks occurred. The new cover will distribute the torque stress differently and also simply add metal. If the cracks had been at the junction of the torque tube to the loader arm this current fix would not make sense but I think it does make sense given where the weak point is on the corners of the inspection hole. I agree however that covering the whole thing up does create problems of its own (how to inspect the hoses, how to monitor for rust or propagation of existing cracks).
I am beginning to think that I'd like to install the thing myself as it will save me time, money and effort to dissassemble the FEL and transport it off island then 80 miles just to have someone bolt a new cover on. I'd want to be able to take it off once a year to check underneath anyway so if I am going to do that I might as well install it myself.
/ KL 120 & 130 loader issue FIX READY #26
From what I see the current torque tube is only welded to the inside of the loader arms, were as the round torque tubes on other loaders appear to go through the entire arm and is welled on both sides...in some cases plated. I can't help but wonder if strengthening the present torque tube is going to shift the stress to a concentrated area at weld connecting tube to loader arms.
/ KL 120 & 130 loader issue FIX READY #27
Good point. Even Kioti's own revised torque tube configuration is welded on both sides. On the other hand, the total length of weld may be about the same as the FEL arm junction with the trapazoidal torque tube on the "cracked" version does spread the load over a fairly large area.
/ KL 120 & 130 loader issue FIX READY #28
Yes, if clearance is not an issue, then a plate like I described welded to the
outside of the tube could be stronger than one on the inside as it could be
welded on its outside perimeter. A large component of strength in this
kind of reinforcement is to be able to use bolts and nuts to secure the
inspection cover, allowing it to provide significant shear force resistance.
The factory inspection cover uses crappy self-tapping machine screws and
no nuts. It is no surprise that cracks start at these holes.
/ KL 120 & 130 loader issue FIX READY #29
"rectangular piece of 1/2" steel plate with a rectangular hole cut into it...I would weld on nuts to the inside of the piece so the access hole
cover bolts can be torqued tight."
Couldn't you just tap the 1/2" plate to accept the bolts?
/ KL 120 & 130 loader issue FIX READY #30
Sure could, but:
Welding nuts on = easy. Tapping holes in 1/2" plate = hard. I may even
wimp out and just use 3/8 plate. I will prob use 3/8" machine screws
(bolts). Also welded on nuts and thru-bolts would be stronger than
tapped holes, assuming the nuts are as thick as the plate.
It seems that Kioti is doing anything it can to avoid any non-factory
welding.
/ KL 120 & 130 loader issue FIX READY #31
welding.
Non-factory welding= non-factory quality= hack job like Highbeam's loader.
Not just the fab work but some yahoo with a stick welder. While I am certain that there are very capable welders out there, I am not certain that the best guys work for tractor shops.
/ KL 120 & 130 loader issue FIX READY #32
Agree..........
/ KL 120 & 130 loader issue FIX READY #33
I should be sure to connect the dots and point out that your particular tractor dealer may have an excellent welder/fabricator on staff and he may be able to perform welding services equal or better to those done by the factory. That's not the case in my experience but you never know.
/ KL 120 & 130 loader issue FIX READY #34
mathey said:
hmmm, looks like a cover to me
That's what I was thinking. Sort of like putting my peas in the napkin when I was a kid.:D
/ KL 120 & 130 loader issue FIX READY #35
I was thinking that the fix being a bolt on repair, kioti should spring to send the Mechanic to the tractor for the repair. If it requires any type of travel they could get him a Hotel and buy him Supper and Breakfast at the local Hooters and if local just the Supper and Breakfast.
/ KL 120 & 130 loader issue FIX READY #36
Breakfast at Hooter's? Now that's an idea. Bet they'd sell a lot of eggs sunny side up. ;)
/ KL 120 & 130 loader issue FIX READY #37
Kudos to NY Kioti and tractorhill for the info. Good job fellas. I think this is a good step, even though I'm not affected I've been feelin' for my Kioti brothers and sisters out there with the KLs. Like Island stated, as long as the cross member's connection to the loader arms is not in question I think this could work. I'd be willing to bet they tested this setup out with cost they're putting into replacement, even to those not cracked. Will be a little tougher checking those lines though... If I had the KL I wouldn't think twice about having the fix installed personally. But I understand those with fabrication experience considering their own fix too. A welded plate fix might be better with a competent fabricator, but I understand Kioti's reluctance to rely on outsourced repairs. Good luck fellas, I hope this puts the issue to bed for your sakes as well as Kiotis(yours first though).
April 30 huh? You dealers are going to be busy beavers....
Update.....
I don't know if anyone has mentioned it yet. The update is on hold, bolts are apparently wrong on the first batch of kits kioti recieved. I was told it will be at least another week before the new bolts come in.
Good news....
It sounds like a extension is being planned beyond the original april date due to this setback.
/ KL 120 & 130 loader issue FIX READY #40
Maybe they needed to use "longer" bolts. I hope they get this straightened out for you guys, that doesn't look like a fix at all to me.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Rooster Weathervane (A55853)
Rooster...
Deere 310L (A53317)
Deere 310L (A53317)
2018 NEW HOLLAND C232 SKID STEER (A60429)
2018 NEW HOLLAND...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A61306)
2022 Greenworks...
2008 MAXX-D FUEL TRAILER (A58214)
2008 MAXX-D FUEL...
