KK blade change
/ KK blade change #1
Tanberry
Bronze Member
N.W.Missouri
TC33DA
I've had a 5" K.K. 3pt brush cutter for about 5 years and the blades have hit alot of rocks and postes ETC and are in bad shape . I purched new blades and a socket wrench big enogh to fit over the bolds to take the blades off . They won't budge . I dont have a cutting torch , At this poit I would break them off and get new ones . Is there any tricks to getting them off ? Thanks
/forums/images/graemlins/confused.gif
/ KK blade change #2
A little heat would be the best. You could try a little propane torch. Sometimes those will heat it up enough to help break it loose.
/ KK blade change #4
Matt, have you checked to see if they are reverse threads? I also have a KK and if my memory is correct, they are reverse threads.
Bob
/ KK blade change
I actually got one off this evening . I had soaked them in diesel fuel last night . I put a socket on and a big breaker bar and with two guys it barly came off /forums/images/graemlins/ooo.gif I was relly just hopening it would break off until I look up the cost at 18 dollers a bolt . I think I'll try to heat the other one up tomorrow and see but it wouldn't budge . Worst case sanareo Ill load it up and take it into town . Thanks for the replys !
/ KK blade change
Oh yes they were revers thread so I had been tignting them
/ KK blade change #7
You could always take off the stump jumper at the drive spindle to make it easier to transport.
Reverse threaded? Yikes! I would have never thought.
2007 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2007 WELLS CARGO...
2001 MACK CH613 T/A DAY CAB ROAD TRACTOR (A64276)
2001 MACK CH613...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
New/Unused CFG Industrial H12R Mini Excavator (A65583)
New/Unused CFG...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
Mahindra Emax 22S Loader Tractor (A66285)
Mahindra Emax 22S...
