Kioti Warranty and Parts Support ?
   / Kioti Warranty and Parts Support ? #11
Eric, I don't understand how KOA can void a warranty without seeing the tractor. When in your warranty period did this happen? Are you willing to share details behind how this happened? Can a company legally get away with doing this? I would be mad as h÷!!. Thank you for posting.
I contacted my selling dealer about my tractor skipping out of range in October of 2015. My dealer contacted Kioti of America who informed my dealer that I had voided the warranty. I called the warranty person at Kioti and asked why was my entire warranty voided and, Tim Fox, the American Importer warranty guy, said:
1) I had worked on my own tractor.
2) I had modified my tractor.
3) I had abused my tractor.
Huh?
1) Tractors are tool carriers. I added my own third function because my dealer, at the time, didn't know how. I didn't modify any electrical system on the tractor and my third function looks like it came from the factory.
2) I was sold on the premise that the tractor would regenerate on average every 50 hours. My tractor was regenerating every 8-12 hours because it was always running rich because it wasn't warming up. This same problem struck the entire diesel industry with Tier IV diesel engines and the field repair among technicians was and is to install a warmer thermostat. As measured, the stock thermostat begins opening at 165 degrees F and is fully open at 180 degrees F. After carefully measuring everything, I installed a thermostat that begins opening at 175 degrees F and is fully open at 185 degrees F and also featured a bypass for high rpm operation as the stock thermostat. This meant that my tractor when not under a load wouldn't cool down enough to go back onto the rich warm-up fuel map and the DPF wouldn't load up as fast as it had been. My T-stat swap effectively solved my problem while also maintaining the factory fuel map as at every temperature, the engine runs on the factory fuel requirements and now my tractor is regenerating at a far more tolerable 25-35 hours.
3) When I specifically asked how I had abused my tractor, Tim Fox, the warranty guy refused to offer any explanation. However, in October 2015, my tractor video collection was rather limited, and I suspect that the video in question was my first and only use of the BX expanded cutting edge mounted on the OEM bucket or that I used a box blade to clean up a pad for building. I used the BX expanded cutting edge to run over light brush that is growing out sphagnum soil. The soil is so soft that I can literally pull the brush out by hand and if this is type of work is deemed abusive, then Kioti's are not designed for any kind of bucket work whatsoever as driving into a lose pile of soil is harder on the loader than running the loader on float over brush to see how well the BX-panded cutting edge worked. Moreover, if using a box scraper is deemed abusive, then again, Kioti’s warranty isn’t worth the paper it is written on, as both tasks are expected uses within the industry for compact utility tractors.
Anyway, the whole episode of having my entire warranty revoked is super disappointing to me and has totally sucked any joy of ownership of this Kioti tractor out of me.
Meanwhile, one dealer told me that they sold five Kioti tractors and all of the customers had mentioned my videos and the Russian importer of Kioti has asked for permission to translate and use my cold weather starting video.
All to say that American Kioti importer, or more specifically their warranty department is amoral and has no idea what their customers are doing with their tractors as nearly every one of us use the tractors for clearing land, material handling, and as tool carriers. My selling dealer certainly knew what my intended uses where, that I wanted and had to have a third function in order to use a grapple or a snow plow on my loader.
Here is a video I made which lead to my thinking that I had been taken by the 50 hour regeneration sales pitch, and the kind of low power my 60 hp tractor was making because the tractor wasn't ever getting warm enough. This video led my carefully puzzling out what thermostat would be a suitable replacement. To test and measure everything, and thankfully, as I am a ASE certified mechanic, my local parts distributor was willing to let me mull around until I found a thermostat that fit, had a suitable bypass and warmer temperature range and solved the problem.
You can feel my frustration in this unpublished video.
My trouble here isn’t with the Kioti dealers, or with the parent company Daedung, but with the amoral culture at the American importer who without ever seeing my tractor voided my warranty and sucked the joy of ownership right out of the deal. Worse, my videos have helped sell a pile of tractors at this point benefitting the American importer, but because of the American importer’s decision to not honor their warranty, they have changed me from a Kioti enthusiast who wanted to help Kioti spread goodwill and confidence in Kioti’s products into a realist who wishes he had never purchased a Kioti tractor.
I wish the American Kioti importer would reinstate my warranty, and fix what I presume is a bent shift fork likely caused from somebody jamming the unsynchronized range fork into gear within the first 7 hours of use before I took delivery of the tractor. That would make me happy and return me to an enthusiastic Kioti tractor owner. Notwithstanding, unless Kioti makes me whole, I cannot recommend their products to anybody because what happened to me, could also happen to you.
   / Kioti Warranty and Parts Support ? #12
Had my Kioti since 2015 first couple mons. had warranty work done very promptly. Today I stopped in at the dealer to pick up a couple oil filters and complained my loader bucket wasn't holding. He handed me a piston with seals on it no charge. Since the loader only has a 1 year warranty that was good. And within 1 hr. their head mechanic showed up at my place and took the tractor for a drive to make sure everything was working properly and went over with me different ways to determine which cylinder had the bad seal. Nothing wrong with the service I've had so far & they don't mind me doing the repairs to avoid extended down time.
Thank you for the detailed reply. This makes me wonder if I want to buy this brand.
   / Kioti Warranty and Parts Support ? #14
Kioti is no better or worse than any of the other top six or seven CUT manufacturers. Warrantees are no longer significantly different and CUTs are very reliable so warrantees are less important considerations than other features.
   / Kioti Warranty and Parts Support ? #15
Kioti Owners: Has anyone had any problems getting their tractor repaired under warranty? The reason I asked is the closest dealer to me sells LS and Kioti Tractors and he is dropping the Kioti line. He states it is like pulling teeth to get these tractors repaired under warranty. I Love these tractors but a statement like that coming from a dealer scares me.
I also would like to know if there are any problems getting parts. I don't want to buy a tractor and have something break then have to wait weeks for parts.
Any information on warranty and parts support would be appreciated.
I'm very interested in the CK2610HST and CK3510 HST.
Truth be told, a warranty is only as good as its dealer.
   / Kioti Warranty and Parts Support ? #16
Best statement yet "warranty is only as good as its dealer"
My Dealer has went out of his way to cover any and everything related to warranty work. That said I have had "other brand dealers" that have done the polar opposite. I have never had the need to contact Kioti North America my dealer has made sure that I am happy without having to go that route. So I would have to say that I am 100% happy with my Kioti and would not hesitate purchasing another one.
From what I have seen posted from Eric I would sat that his machine has been tested to a lot of limits and just wonder how manufactures units would perform in the same test. With that said maybe Eric could be a tester for all manufactures and report on all of them instead of just one??
   / Kioti Warranty and Parts Support ? #17
My tractor leads a pretty easy life mostly doing loader work transporting piles of logs and brush that I cut by hand or running a brush cutter.
   / Kioti Warranty and Parts Support ? #18
I've had numerous warranty claims done. Close to 10. Only two I would classify as critical. All my fuel injectors needed replacing, tractor had zero power. The most recent, the HST transmission not working correctly. My dealer has been great taking care of my issues. My only complaint about the warranty work is it seems parts take a while to come in. Tractor has been down for almost three weeks trying to get the HST transmission issue fixed. During this down time I have been wondering if I bought the correct tractor. While the dealer has been great, I wonder what is going to happen (financially) once the warranty runs out. My dealer also sells New Holland; been seriously thinking about trading tractor in for a New Holland. I love my Kioti when it works. But long term reliability may not be there. Been seeing a lot more Kioti advertisments and they even sponsered a Nascar race a couple weeks ago. If they are going to be serious in the US, that type of business of voiding warranties isn't going to work.
   / Kioti Warranty and Parts Support ? #19
All brands from time to time will have issues needing warranty attention. I think in Eric's case the importer was looking for a reason to deny the claim. This is not good publicity for Kioti. If I was denied warranty and felt it was unfair you can bet your sweet petunia that everyone would know about it. Even now if Kioti tried to make it right the damage is done. I hope they change their mind for you Eric. I'm sure the situation has left a bitter taste in your mouth. Good luck and keep us posted.
   / Kioti Warranty and Parts Support ? #20
I have owned my CK 30 since 09 (new) love it, it starts every time instantly, and never have had a problem..I would highly recommend them.
2011 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A58018)
2011 INTERNATIONAL...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
2015 DRAGON 137BBL DOUBLE CONICAL VACUUM TRAILER (A58214)
2015 DRAGON 137BBL...
2004 Ford F-150 (A56858)
2004 Ford F-150...
2012 ADDCO S/A Towable Arrow Board (A55973)
2012 ADDCO S/A...
kids dirt bike (A56859)
kids dirt bike...
