Kioti Tractor CK25 engine question/problem
/ Kioti Tractor CK25 engine question/problem #1
jon owens
Eatonville, Wa
2005 Kioti CK25
Hello to all. I am new to this site and to owning a tractor, I currently own a kioti ck25 ht and let me first give you my opinion, do not buy a kioti product as they are unreliable machines. I have had three ignition switches go bad, a cracked front loader and a loader bucket that split open due to cheap and thin steel material. Now here is my problem and question. Yesterday I was mowingmy field with a brush cutter using the PTO, everything was going good when I heard a knock in the engine. About 20 minuets later the knock turned into a loud rattling/ knocking, and the engine started to stop, so I pushed in the clutch, disengaged the PTO and shut off the engine. Question does this sound like a brocken rod and or piston? No smoke, no fluids were observed and when I tried to restart all I heard was a knocking sound so I shut the engine off, and now my tractor is stuck out in my field with the loader and attatchment in the down position.
I dont think kioti will help due to the tractor being out of warranty since it is 7 yrs old.
Any advise or troubleshooting ideas would be helpful.
BTW the tractor is full of oil, radiator is full, air filter is new.
Thank you
Jon
/ Kioti Tractor CK25 engine question/problem #2
Sounds like a connecting rod bearing gone bad, or a bad injector pump, or injector. Until you get the tractor back to a place where you can inspect it, or drop the oil pan, and inspect the lower end it's hard to be certain. Sorry to read about your troubles. Kioti are usually a good product.
Thank you for responding, I am checking the fuel to see if water is in the system.
Jon
/ Kioti Tractor CK25 engine question/problem #4
You might do a little better on answers by asking in Kioti area.
Good luck as sounds expensive.
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
2020 Bobcat MT85 (A64126)
2020 Bobcat MT85...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
Peterson Horizontal Grinder (A62613)
Peterson...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
