Kioti tier 4 issues?
/ Kioti tier 4 issues? #11
What technologies is Kioti using to meet tier 4 final?
I assume Common rail on all kioti over 25hp?
DPF?
EGR? EGR cooler?
any using SCR? w/Urea injection?
I noticed that the fuel tank is under the floorboard. My DK is under the hood. I would think the engine heat would help keep the fuel from gelling on mine better in the winter.
If you have a DPF. I would make sure that the area around this filter is kept clean of grasses and weeds In the summer. Could be a fire hazard.
Yep, Common Rail DI, DOC, DPF, EGR w/cooler. no urea.
The fuel might get some heat off the engine with a tank on top, but I'll take the floor mounted tank any day, way easier to fill.
/ Kioti tier 4 issues? #12
DPF?
EGR? EGR cooler?
Not a very subtle way to beat your chest about your DK :laughing:
/ Kioti tier 4 issues? #13
My tractor is in northern Minnesota, we're colder than the lower 48. My 6010 doesn't warm up below 40 degrees, and so I put in a warmer thermostat and pulled the clean out screen and put in cardboard to block airflow. Never warming up makes the engine run rich, requiring more frequent regen cycles. You guys are unlikely to have these issues.
I'm not sure why you're having problems with the engine warming up. I've used mine all winter to clean the cattle yard and barn and feed and it warms up. Depending upon how cold determines how long but I'm usually in a tshirt after 20 min.
/ Kioti tier 4 issues? #14
Because I'm doing different kinds of work. Mostly loader work.
/ Kioti tier 4 issues? #16
Default Kioti tier 4 issues?
Considering an NX4510. I have been reading up on tier 4 tractors. Seems as though some manufacturers achieve the emission requirement utilizing different technologies.
For those that have tier 4 machines, what are your experiences?
Any negatives (other than increased initial costs of course)?
Read hear...http://www.tractorbynet.com/forums/kioti-buying-pricing/330045-my-dealer-still-has-dk.html, have one shipped......... save yourself a lot of problems down the road.
2019 BOBCAT MT55 WALK BEHIND SKID STEER (A59823)
2019 BOBCAT MT55...
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
7021 (A55851)
7021 (A55851)
