Kioti PTO help needed please
/ Kioti PTO help needed please #1
osobuco
Indy, IN
Kioti LB1914
Hi all. I am new here and I have a problem with the pto on my LB1914. it kept disengaging when under a load and now the lever is flopping around and it will not engage at all. there is not any end play in the pto shaft and no leaks. I am thinking it is a broken or bent shifter fork. to repair this will I have to split the tractor or can I access it through the back?
thank you for any and all help
mike
/ Kioti PTO help needed please #2
Check what the lever operates. Is there linkage involved or does it connect directly to a shaft protruding from the transmission case?
There very well could be a problem externally.
2022 CATERPILLAR 914 WHEEL LOADER (A65053)
2022 CATERPILLAR...
New/Unused Wolverine 72in Quick Attach Rock Bucket (A65583)
New/Unused...
Back Buddy (A64194)
Back Buddy (A64194)
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
2009 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A64556)
2009 Chevrolet...
2022 ALLIANCE NORTH AMERICA AIR MAN SDG 25 GENERATOR (A65643)
2022 ALLIANCE...
