Kioti oil filter problem
/ Kioti oil filter problem #1
dxturner
None
Doing the 50 hour service on my DK4210HST and can't believe how difficult it was to get the filter off. Not only was it hard to get a wrench on with any room to turn, it was so tight I thought maybe I just wasn't strong enough!
Finally, I got desperate and used an old trick my Dad used when he didn't have a filter wrench. I drove a screwdriver through it. That worked and I learned I was strong enough at least to bend the screwdriver! ... see photo.
Are they that tight from factory or was it dealer prep?
/ Kioti oil filter problem #2
Factory.
/ Kioti oil filter problem #3
I always thought that was a silly trick. If it doesn't work you are stuck, can't move the tractor. I think every manufacturer has gorilla's on the assembly line putting filters on.
/ Kioti oil filter problem #4
I guess you switched to a more robust screwdriver after the bending incident.
/ Kioti oil filter problem #5
Yep. My theory is they aren't lubing the gasket. New filter screwed on to dry threads and a dry surface as it is assembled.
/ Kioti oil filter problem #6
Just wait till you get to the hydraulic and HST ones. That's where it gets really fun really fast. :)
As dusty said, it's just because the put (read: over tighten) the filters on without lubing the seal. Contrary to popular belief, it's not because they painted of the filters.
/ Kioti oil filter problem #7
exactly my thoughts when both hyd filters were extremely difficult to remove @ 50 hrs. my take is that the factory wants no chance of accidental filter disengagement. glad no one was around for my choice words...
/ Kioti oil filter problem #9
Those strap wrenches are good (if you have the room beside the filter can). Then I moved on to a tri-claw, as in the photo below; but for my Yamaha ATV where space is really tight, I bought a cup type - brilliant!
/ Kioti oil filter problem #10
my experience w/cup type wrenches is that they just spin before proper torque is applied to either tighten or loosen filter. at least on my rigs, but yes, handy.
/ Kioti oil filter problem #11
I have this set works great no problems:
willy
Thanks all, for the tool tips! I have the strap type remove but that didn't work. Will look for the cup or claw type since they seem to be better for tight places.
(4)-8 LUG FORD WHEELS (A62131)
(4)-8 LUG FORD...
HOMEMADE FIRE PIT (A62131)
HOMEMADE FIRE PIT...
4 Shelf Rolling Cart 6ft x 3ft (A61165)
4 Shelf Rolling...
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
