Kioti oil filter problem
/ Kioti oil filter problem #1
dxturner
None
Doing the 50 hour service on my DK4210HST and can't believe how difficult it was to get the filter off. Not only was it hard to get a wrench on with any room to turn, it was so tight I thought maybe I just wasn't strong enough!
Finally, I got desperate and used an old trick my Dad used when he didn't have a filter wrench. I drove a screwdriver through it. That worked and I learned I was strong enough at least to bend the screwdriver! ... see photo.
Are they that tight from factory or was it dealer prep?
/ Kioti oil filter problem #2
Factory.
/ Kioti oil filter problem #3
I always thought that was a silly trick. If it doesn't work you are stuck, can't move the tractor. I think every manufacturer has gorilla's on the assembly line putting filters on.
/ Kioti oil filter problem #4
I guess you switched to a more robust screwdriver after the bending incident.
/ Kioti oil filter problem #5
Yep. My theory is they aren't lubing the gasket. New filter screwed on to dry threads and a dry surface as it is assembled.
/ Kioti oil filter problem #6
Just wait till you get to the hydraulic and HST ones. That's where it gets really fun really fast. :)
As dusty said, it's just because the put (read: over tighten) the filters on without lubing the seal. Contrary to popular belief, it's not because they painted of the filters.
/ Kioti oil filter problem #7
exactly my thoughts when both hyd filters were extremely difficult to remove @ 50 hrs. my take is that the factory wants no chance of accidental filter disengagement. glad no one was around for my choice words...
/ Kioti oil filter problem #9
Those strap wrenches are good (if you have the room beside the filter can). Then I moved on to a tri-claw, as in the photo below; but for my Yamaha ATV where space is really tight, I bought a cup type - brilliant!
/ Kioti oil filter problem #10
my experience w/cup type wrenches is that they just spin before proper torque is applied to either tighten or loosen filter. at least on my rigs, but yes, handy.
/ Kioti oil filter problem #11
I have this set works great no problems:
willy
Thanks all, for the tool tips! I have the strap type remove but that didn't work. Will look for the cup or claw type since they seem to be better for tight places.
2013 Freightliner Road Tractor (A61165)
2013 Freightliner...
(10) 36' HEAVY DUTY INSULATED PANELS (A62131)
(10) 36' HEAVY...
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
2023 CATERPILLAR 299D3 XE SKID STEER (A62129)
2023 CATERPILLAR...
2012 Great Dane 53ft. T/A Reefer Trailer (A61568)
2012 Great Dane...
17394SFL (A61568)
17394SFL (A61568)
