Kioti Mechron windshield build
/ Kioti Mechron windshield build #1
laurencen
saskatchewan Canada
Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
not a large project but since I picked up a Mule for the lake having a windshield is a must have, I looked at the factory and they are made of 1/4 plexiglass, the mounting is flimsy and I was quoted 1500 dollars, so went and picked up a sheet of 1/2 lexan, wanted a solid front, the 1/4 was too flexible spanning the 60 inches between the bars, I produce the half clamps of plastic for hydraulic cylinder supports just had to open them from 1 1/2 to 1 3/4 diameter
mounted the blocks on the frame, cut a cardboard template and jigsawed the main section to nest under the roof, the half inch was too heavy to bend and heating was not a option so again cut a template and sawed out the lower part, after fitting I routered all the edges 1/4 radius, mounted and applied a generous bead of silicone to both outside and inside of the joint
total cost just under 300 dollars, time 3 hours and its solid, the weight was around 40 pounds but doubt the machine will notice
thoughts DSC_0082.JPGDSC_0083.JPGDSC_0084.JPGDSC_0085.JPGDSC_0086.JPG?
/ Kioti Mechron windshield build #2
What a great looking job! Saved quite a bit of money too. Thanks for sharing.
/ Kioti Mechron windshield build #3
Looks great, and very sturdy. Rather than make it in two pieces, why not just project it straight down from the top? Which brings up a question, how/where does the hood open?
mjw, the hood hinges at the windshield, if it comes straight down it would be 4 inches over the hood,
2018 Trail King Lowboy (A63689)
2018 Trail King...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
Schulte Batwing Rotary Brush Cutter Tractor Attachment (A61572)
Schulte Batwing...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A  SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
CASE TV370 SKID STEER (A62129)
CASE TV370 SKID...
