Kioti Mechron 2200 steering stiff
   / Kioti Mechron 2200 steering stiff #1
laurencen
saskatchewan Canada
Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
had this machine for several yeas, unlike the newer its not power steering, either its me getting old and weak but the steering feels way tighter than I seem to recall, looked at the front end and nothing appears to be serviceable, before I start getting into it any other owners feel the steering is tight to turn, have not tried it byt doubt this would correct itself unless one turns the wheel back straight
   / Kioti Mechron 2200 steering stiff #2
Have you ever greased the front suspension?
Sadly no, machine has less than 75 hours on it, looked on the weekend at the steering there is no grease points, both u joints and tie rods are sealed, there is grease nipples for suspension?
so finally after a couple hours got it free again, after taking the U joint off the issue was in the steering wheel bushes, rather than taking the dash out I git the steering wheel nut with a piece of brass, not hard but enough to free it up, no idea what the build inside is but turns with a feather now, later this fall will get a service manual and take it apart
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
bad boy zero turn 72 (A56859)
bad boy zero turn...
CATERPILLAR SSL PR118M HYD POWER RAKE (A60429)
CATERPILLAR SSL...
2018 Honda Rubicon TRX500FA5 4X4 ATV (A59231)
2018 Honda Rubicon...
2018 HINO SA (A58214)
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
