Kioti lb1914 Tractor
/ Kioti lb1914 Tractor #1
agman5735
My hydraulics are not working. The 3 point will raise if RPM's are raised.With no implements hooked on the 3 point. But will not raise at an idle.
I have taken out the filter and seems to be okay. Also removed the plug on the front of the pump with engine running but very little fluid comes out. Seems that with this test ,fluid should be under pressure and shoot out. What has been anyone's experience with this problem. Thanks
/ Kioti lb1914 Tractor #2
Mornin Agman,
Im not familiar with your tractor but my first thought is that you have a damaged hydraulic pump, key sheared etc... You need to get a service manual for that machine, check hydraulic pressure etc... But thats what it sounds like to me, there are a bunch of guys that own that tractor that can offer more help ! Good Luck!
BTW welcome to TBN !
Thanks i have a manual coming. Where is the suction screen located. agman
/ Kioti lb1914 Tractor #5
Does the 1914 have the little valve behind your heel just under the seat? My CK 20 does. If this gets bumped, it can cause your symptoms.
2014 PETERBILT 579 MID-ROOF SLEEPER (A67714)
2014 PETERBILT 579...
2100 GAL WATER TANK (A68842)
2100 GAL WATER...
2006 FRAC TANK 500BBL WHEELED (A68842)
2006 FRAC TANK...
HYDRAULIC MANIFOLD SKID (A67714)
HYDRAULIC MANIFOLD...
OUTBOARD ENGINE STANDS (A66738)
OUTBOARD ENGINE...
GROVE RT520 ROUGH TERRAIN CRANE (A67714)
GROVE RT520 ROUGH...
