Kioti filter cross reference number list (all models)
   / Kioti filter cross reference number list (all models) #101
The site will not allow me to edit my post #98, so here is the continuation:
2017 Kioti CK2510(H)
Engine Oil Filter = WIX 51381*
Hydraulic Filter = WIX 57098**
HST Filter = WIX 51663***
Fuel = WIX 33507 is not correct for this 2510 tractor, the diameter is too large. I will be trying another # soon from my NAPA dealer.
* (That would make it a NAPA 1381) and it worked fine. Same/similar outside dimensions, correct spin-on threads, and the seal diameter measures the same as the original Kioti factory filter.
**This is the long one, underneath, mounted vertically. Same diameter, same length, same seal diameter. Internals look pretty much the same as factory filter. Those who have reported that this factory filter is hard to remove the first time are correct. It was a bear! I used an old universal coiled spring style filter wrench to grasp it with a 1/2" breaker bar for leverage. Was still a struggle. Be prepared for a workout.
***This is the one by your right heel, near the floor board, mounted horizontally. This filter appeared the same diameter as the factory HST filter, except it is slightly shorter. I actually like this, as the factory filter stuck out quite a bit and my heel would rub on it. This filter is still long enough to protrude so that you can get a filter wrench (strap or cap style) on it for removal next time. You can cross reference this WIX# on the WIX site and possibly get one that is the same length as factory, I have not done that yet.
   / Kioti filter cross reference number list (all models) #102
Greetings.
I'm due for a change for all filters and so I was rereading this thread.
I've been using WIX 51324 (NAPA Gold1324) for my oil changes. I used Kioti HST and Hyd the first time around (I owed the dealer). Tis time I was looking to see what's available.
Cummins Filtration - Catalog - Part Search says there is no cross reference for the T2185-38031 or the T2195-38031.
WIX said :
Part Number Manufacturer Wix Part Number
76KD10331 KIOTI 33389 Fuel Filter (NAPA 3389)
P821575 DONALDSON 46438 Air Filter
Part Number Comments
T219538031 This is a valid competitive part number and there is no replacement at this time. (HST filter)
T218538031 This is a valid competitive part number and there is no replacement at this time. (Hyd Filter)
Where did you get info on the HST and Hyd filters?
BTW nice to see another CK2510 owner.
   / Kioti filter cross reference number list (all models) #103
I've been searching prices and I can't believe what I'm finding. The WIX 51663 is listing at $7.86 (Rockauto), $8.14 (FleetFilters), $6.90 - $14.69 (eBay) and $24.98 (Jet.com) vs $23.51 and $33 for the Daedong T2195-38031 filter. The WIX 57098 is more even across the board $24.79 at RockAuto, $36.66 at TraderJoes and $42.70 at my local Kioti dealer for the Kioti filter.
I'd save the money if I could be sure it's a comparable filter but I can't find any specifications for Kioti filters.
   / Kioti filter cross reference number list (all models) #104
Is there a way we can make a searchable database for user verified cross-references and imbed it in the site? I think that would be a huge value add.
   / Kioti filter cross reference number list (all models) #105
It would be nice to have such a search element. But I imagine there would be some liability issues about who is responsible for the accuracy of the list. When I'm looking for something specific on a forum about a new filter, and I want to see if anyone has said anything about it within the forum, I've found searching through google, specifically with the website you want to search through, works pretty good.
Example, if I'm looking for anyone who has mentioned the new Wix WL10113, a cross reference for Kioti T4620-38032, a DKse hydraulic filter, I type into the google searchbar, "site:TractorByNet.com | Compact tractor forums, news, reviews, information. wix wL10113 kioti T4620-38032". this will only show results from tractorbynet, with those key words
   / Kioti filter cross reference number list (all models) #106
Well, as with any information you find on a forum or the internet, the user needs to assume responsibility for what they do with the information they find.
Maybe I'm just a little bit lazy, but sometimes I search for hours, only to find out the one source for information wasn't tagged right, or some different terminology was used, thus hindering my search.
Thanks for the hydro filter cross reference, that's one I've been looking for. :)
   / Kioti filter cross reference number list (all models) #107
:drink:
I haven't found the Wix WL10113 available online just yet, but the napa cross is 400113, which i see is available online, for about the same price as kioti. So at this point I have a cross for every filter for the DKse tractors. Cant say that about many tractors these days.
   / Kioti filter cross reference number list (all models) #108
:drink:
I thouth that NAPA filters are made by WIX. The part # is usually the same with one leading digit removed.
   / Kioti filter cross reference number list (all models) #109
Yes thats right, but for some reason the filter is not available as a branded Wix filter. Just Napa. Also, the numbers are not what we would usually find for a Wix to Napa branding. This Wix number WL10113 should be a Napa 0113, but its not, its Napa 400113. So there is something going on here that's out of the ordinary.
But this Napa 400113 it's still a good crossover for the kioti T4620-38032 according to both Napa's and Wix's websites.
   / Kioti filter cross reference number list (all models) #110
Any filter cross references for a LK3504?????
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A56436)
Gleaner N630 Corn...
SKID STEER ATTACHMENT HAMMER (A58214)
SKID STEER...
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
