Help with cross reference for Jinma 284
   / Help with cross reference for Jinma 284 #11
If its a Yangdong 385 engine on you tractor, can be confirmed by the data plate on the valve cover, most of us use the Fram PH3950 or equivalent. It would help if you list the numbers you tried. The PH3950 has a metric thread of 20x1.5 while the PH16 you put on is a 3/4 16 thread. I am guessing you have the wrong filter on it now and may blow off also. While the treads are different they are the same filter, that is the PH3950 and PH16 in respect to size and bypass pressure.
Also, I have been told you can take the filter off and unscrew the nipple to lengthen it.. Perhaps yous is screwed in too much?
Here is the filters I use on my 2004 Jinma
Air= Purulator A42019
Oil= Fram PH3950
Fuel= Fram P6503
Been using them for 7 years and around 800 hours with zero issues.
Check that nipple first. I really believe you have the wrong threaded filter on it so be careful and get it changed out.
Chris
   / Help with cross reference for Jinma 284 #12
I also unscrew the nipple on my JM354 and it now takes the standard FL1 Motorcraft filter. I thought Ranch Hand or one of the vendors had a new nipple just for this problem? If I had the filter issue I'd but the new nipple just to be able to use the standard filter. bjr
John Deere 3025E (A53317)
John Deere 3025E...
2011 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59575)
2011 FREIGHTLINER...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
John Deere 4600 (A53317)
John Deere 4600...
Towable Tank (A59228)
2011 Chevrolet Silverado 2500 Pickup Truck, 127808 Miles, Utility Rack - GREAT WORK TRUCK (A56438)
2011 Chevrolet...
