Kioti DK55 Power steering issues
   / Kioti DK55 Power steering issues #1
jimglassford
Manchester, mi
Kioti DK55, Ford/New Holland 4630
I have a 2003 DK55 with 2600 hours. It hase been a real money pit. I now have an issue with the power steering. You can rotate the steering wheel as many times as you want when turning. When going is a straight line, you constantly have to correct with the wheel rotating one direction. This tractor has the earlier single acting hydraulic cylinders on the front axle so the problem can't be leaky seals. I see others have posted the same issue on smaller Kioti's. However, no one has ever diagnosed the problem. I see a few members state they finally just took the tractor to the dealer but never reposted the repairs made at the dealer. I believe there is an internal problem in the steering control valve. My repair manual tells you home to disassemble the unit but I do not believe parts are available.
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2005 Big Tex 10PI 16ft. T/A Utility Trailer (A49461)
2005 Big Tex 10PI...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2005 WINNEBAGO WORKHORSE W22 RV (A50854)
2005 WINNEBAGO...
2018 Toro Sand Pro Bunker Rake with Edger/Broom (A49461)
2018 Toro Sand Pro...
