Kioti CK30
/ Kioti CK30 #1
shovelrider
USA
YM1700 w / fel
I sold my Yanmar and bought this 2008 Kioti ck30 4x4, my question is on the rear stabilizer bars. Can i change them out for the chain type and also where can i find a complete grill guard frame +/- the inserts? I love this tractor and it's something my wife can handle also. Thanx in advance
/ Kioti CK30 #2
My question is on the Three Point Hitch rear stabilizer bars. Can i change them out for the chain type?
I have been posting on T-B-N since 2011. You are the first OP ever to want to exchange stabilizer bars for chain style stabilizers.
Are your Kioti rear stabilizers the pinned, telescoping style, or something else?
Why do you want to make this conversion? Chain style stabilizers are much slower and cumbersome to adjust. Nor can you push an implement with chain stabilizers. You can push implements with rigid stabilizers to a certain extent. Pushing can be useful in ground contact work, especially with a Box Blade.
/ Kioti CK30
I know nothing about them, however i did read some of my owners manual. But not sure how to adjust or set, they are pinned to the axle stubs then to the lift arms. Not sure i know which hole to pin or just let move freely. Just bought used 900 hrs. $10k, thank you and i understand about the chains etc..
/ Kioti CK30 #4
There is little difference in function between the state-of-the-art pin adjustable rigid stabilizer on your Kioti now and obsolescent, though cheaper chain stabilizers.
With a Three Point Hitch implement mounted and raised a tad above the ground, you telescope one side, then the other, to prevent the implement from colliding with the tractor rear tires and almost always to center the implement between the rear tires. Pins maintain the adjustment length you select. (Occaisionally the stabilizers may be adjusted to offset an implement slightly,)
I would stay with the pinned, telescoping, rigid stabilizers you have.
T-B-N ARCHIVE: adjusting rigid telecoping stabilizers site:tractorbynet.com
/ Kioti CK30
With a Three Point Hitch implement mounted, you telescope one side, then the other, to prevent the implement from colliding with the tractor rear tires and almost always to center the implement between the rear tires. (Occaisionally the stabilizers may be adjusted to offset an implement slightly,)
I would stay with what you have.
yes sir, like i said, i don't know much about this model but it's what i needed. Both right now has no pin in the slots, i guess so they can be free moving. Just getting used to it. Thank you Jeff, have a great day.
/ Kioti CK30 #6
Both right now have no pin in the slots.
Clevis pins in great variety are available at Tractor Supply Company for $1. You want a close but not tight clevis pin fit.
Without pins making the stabilizers rigid, it is a matter of time until an implement gouges one or both of your rear tires.
It is time to update your tractor make and model in your T-B-N PROFILE.
YM1700 w / fel
/ Kioti CK30 #7
So, I just want to make sure I have this right, your telescopic links are missing the pin to secure them?
Here are a few online sources for parts I've found, just in case I can't get to my dealer. I'm sure they'll have turnbuckle links. That said, consider getting the pin you need for the telescopic ones; once you get it operational you'll be happy you went that route.
And lastly, here is my local dealers website...
Enjoy the Kioti, they're good little tractors.
/ Kioti CK30 #8
I see the pin on the picture. It's right on the first hole.
This style of stabilizers is very nice and easy to use. You hook up the implement, lift it up a little bit, then use the pins till you get very little side to side play.
If you need side to side play, put the pin on the slot on both sides and it will move side to side.
/ Kioti CK30 #10
It looks like the pins may be there.
They are just in the holes where they do no good (need to be moved farther forward where they actually function)
/ Kioti CK30 #11
It also looks like one of the adjustable lift arms may not be latched.
/ Kioti CK30
i put the pin in the sloted holes and need to latch the arms back down. Thank you. Also, i've been looking for the oil/filter cross reference but haven't found it here yet. Put 2 hrs. on it so far, was 944 hrs. have 8k in so far, this is a great utility tractor for sure.
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2022 Bautista Welding and Custom 40ft. 10 Ton T/A Gooseneck Flatbed Trailer (A61573)
2022 Bautista...
Timpte 720 All Aluminum 7000 Tilt Trailer (A63689)
Timpte 720 All...
(1) 24X9.50-12 TIRE W/ 5 LUG RIM (A64280)
(1) 24X9.50-12...
SEARS ELECTRIC AIR COMPRESSOR (A64276)
SEARS ELECTRIC AIR...
UNUSED WOLVERINE QUICK COUPLER 3 (A64281)
UNUSED WOLVERINE...
