Kioti CK30 Hydrostatic issue
   / Kioti CK30 Hydrostatic issue #1
CanuckGT
Bronze Member
Dino Valley,Ab Canada
Kioti CK30 HST
I just changed my Hydro/hydraulic fluid and used Mobil hydraul synthetic blend fluid,changed both filters (used Bobcat filters) as I have no dealer nearby.
When I first changed the fluids all seemed well but last night I used it a bit and noticed my hydrostatic foot pedal was sticking when going forward, also the tractor movement was jerky.
when I changed the fluids I put in about 28L,checked the level,started the tractor and let it idle for a bit,checked level again and seemed good.I will check the level again today but I am assuming it will be good?
Any ideas whats going on here?
   / Kioti CK30 Hydrostatic issue #2
Did you try all 3 gear ranges? Is it the same in each? What about the loader and 3ph, are they operating ok?
   / Kioti CK30 Hydrostatic issue #3
In reading your post you mentioned, " foot pedal was sticking when going forward,". Could it have something to do with the pedal or linkage. Hopefully this morning it works perfectly for you. :)
   / Kioti CK30 Hydrostatic issue #4
You may be airbound. Did you fill the filters before installing them to reduce air entering into the hydraulics? If not, there may be air pockets which are affecting proper operation of the hydraulics. You could drop the filters and fill them now, and try to reduce the air entering the system.
you know, I forgot to add fluid in the filters,|I guess I better check this out but sounds logical...dang..
So, does the air work itself out some how??
Haven't checked it out yet....darn internet,coffee...:D
   / Kioti CK30 Hydrostatic issue #6
I have never added oil to any of my filters over the years and no problems. Guess we will see if this is the problem, really have never heard about adding oil to a filter. Just saying. :)
   / Kioti CK30 Hydrostatic issue #7
It is better NOT to put oil in your filters, the pumps will fill the filter and push oil into the reservoir where it is vented. This way the filter see only filtered oil. No oil is not 100% contamination free.
Have you greased the 2 foot pedal grease points under the operator platform recently? Also spray some lubricant on the pins and linkage points under there.
Note: Refill capacity is 30.7L, you may be a little low.
   / Kioti CK30 Hydrostatic issue #8
I haven't had to fill my filters with oil. Doing that would make a mess when refitting the hydrostatic one.
It could be coincidence that the little centralizer piston for your footpedal could be sticking. It is easy to free up.
Well took her out today ,started by lubing up the hydro linkage and piston under the foot pedal with wd40, then proceeded to work on a small drainage canal.
At first it was still sticking in forward only,but seemed to work in as I used it,after a bit of work it was working good again,I guess iut was just fluke that it failed the same time I changed fluid..at least I hope its going to keep working!
I did check my fluid level as I only put about 28L back in,figuring their would be some residual left so it should be close.The level is very hard to detect (fluid is clear) but was able to see it good if I pulled the dipstick out and turned it upright and watched the oil pool on the stick,it was at the full mark.
Thanks for all the help!
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
Mini Margaritaville Truck (A55853)
Mini...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
